APS pullies....simple question..... I hope
Old Jun 2, 2003 | 08:49 PM
AS84's Avatar
AS84
Default APS pullies....simple question..... I hope
I'm looking into a crank pulley from asp. I notice that it retains full charge at 750 rpm. But, if you purchase the alt pulley with it, full charge at idle is increased to 950 rpms....why is that? Will the underdrive pulley on the alt help ET. I always thought that putting the pulley on the alt. would help charge at lower rpms, but I guess it does just the opposite.
Old Jun 2, 2003 | 09:01 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: APS pullies....simple question..... I hope (AS84)
A 20% underdrive crank pulley is 20% smaller in diameter than stock.
If you leave the stock alt pulley it will run 20% slower and can leave to charging problems at idle with full accessories on.
If you put a 20% smaller in diameter pulley on the alt, the alt will spin at stock speeds and there will be no charging issues at idle.
If you put a 20% larger in diameter pulley on the alt, the alt will spin 40% slower and will definitely lead to charging issues at idle.
So look to the relative size of the alt pulley to know the results.
Old Jun 2, 2003 | 10:03 PM
AS84's Avatar
AS84
Default Re: APS pullies....simple question..... I hope (65Z01)
That cleared it up, thanks.
I think I'll do both pullies, since the bottle heater will draw some extra amps.
To APS pullies....simple question..... I hope
