start up with sc
Old Jun 8, 2003 | 04:18 PM
old salt's Avatar
old salt
Default start up with sc
i have been working on getting my car running better. i have most of the tuning issues worked out execpt. starting. no matter what i do it seems i cant get enought fuel at cranking to fire up. i hit the air cleaner on the supercharger and it fires up and runs fine. this is only on warm startup. cold it fires up great. i have a 383 ,lt4 heads & intake, hotcam, 36 lb inj. paxton 10lb s.c. . any help would be appreciated.
Old Jun 9, 2003 | 03:38 PM
drive it's Avatar
drive it
Default Re: start up with sc (old salt)
???Could you define that?! And are you sure it needs more fuel? On mine I've found that it has a hot soak restart rich condition-which is the most common one. I've had to decrease the crank fuel vs temp table to help out with it.
Old Jun 9, 2003 | 07:51 PM
old salt's Avatar
old salt
Default Re: start up with sc (drive it)
i usually hit it with a spray of fuel or carb cleaner.
Old Jun 10, 2003 | 01:33 AM
drive it's Avatar
drive it
Does sound like it's lean then...increase the crank fuel pulse width vs coolant temp table should do it.
Old Jun 14, 2003 | 02:12 PM
old salt's Avatar
old salt
thats what i was thinking. at idle my injector p/w is around 10 when i am cranking it is about 4 to 5. i was looking in tunercat and couldnt find a "warm start" or cranking enrichment table. also my gms per sec from my maf shows 00 at cranking is this normal?
To start up with sc
