front speakers
Old Jun 9, 2003 | 09:27 AM
The Hobbit's Avatar
The Hobbit
Default front speakers
I have just installed a new Alpine autochanger in my 86 vert. So as to keep the original look I have hidden it and left the Bose in place.
Question:
Does any know if the speaker units in the front amplifiers are High impedance or can I wire to them from the new unit ?
Are the grills in the dash pad for real or are just dummies, if so how do I get to them ?
How the h?ll do you get the speaker boxes out of the front doors ????
What have other people don ?
Thanks for all the help as usual.
Old Jun 9, 2003 | 04:33 PM
K87ZZ4's Avatar
K87ZZ4
Default Re: front speakers (The Hobbit)
I believe the stock Bose speakers are incompatible with new equipment (decks or amps).
Yes, you can put speakers behind the holes in the dash pad. The shop I had install mine took the dash pad out and put some cloth over the holes... looks great.
I did manage to get the speaker boxes out of the front doors with some 'manipulation'. I don't recall exactly what I did, since it was a few years ago, but I was able to get the speaker boxes out without damaging/cutting anything. So, if I ever need to, I can put the original system back in.
I have totally replaced my sound system, but kept all original speaker grills... the only thing you can see is the in-dash head unit/changer. Two amps and cross-overs are mounted in the stow area behind the passenger seat.
BTW, which autochanger did you buy?
Old Jun 10, 2003 | 10:45 AM
The Hobbit's Avatar
The Hobbit
Default Re: front speakers (K87ZZ4)
Thanks for the info, I got an Alpine 0134r with a chms630 changer.
I got this because it was cheap and has a remote, with the monza system and the top down 'hi fi' is a bit hopeless.
Thanks again
Old Jun 10, 2003 | 02:24 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Barry,
We need to get together sometime. Are you going to the Nats at the end of the month?
Old Jun 10, 2003 | 09:43 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The Bose dash has solid plastic filling the speaker holes. I removed the mesh cover, and cut a hole in the plastic to mount my tweeters below the surface. If you have 4x6s, they might bolt right up to the plastic (after cutting out the hole) without any other modifications.
I believe the part was the same between Bose and non-Bose, except the hole isn't cut out.
I don't know much about it, but the Bose speakers I think have a non-standard impedance and can't be driven with a normal aftermarket stereo amp. Or at least they won't sound like they should if you do.
Replace those Bose speakers, they're old and nasty by now. I kept all the factory speaker covers, so it all looks stock except for the headunit.
Search the archives for info on removing the door boxes.
Old Jun 11, 2003 | 02:46 AM
K87ZZ4's Avatar
K87ZZ4
... with the monza system and the top down 'hi fi' is a bit hopeless.
Don't give up hope! With tweeters in the dash pad and a good amp(s) to drive all the speakers, it can rock even at freeway speeds! Mine cranks up plenty loud and with the new subwoofer I just put in, it rocks your socks off no matter how fast you're drivin' :D It's not especially cheap, though.
Old Jun 11, 2003 | 04:33 AM
The Hobbit's Avatar
The Hobbit
Thanks for all the encouragement, I will keep at it.
Ray: It would be good to get together, I will defiantly be going to the nationals. If you get time give me a ring and maybe we can meet up somewhere.
To front speakers
