Ac?
Old Jun 16, 2003 | 06:40 AM
Corvettehumlan's Avatar
Corvettehumlan
Default Ac?
My AC does not work that good.But the medium level is not low.What else can be wrong?
[Modified by Corvettehumlan, 2:33 PM 6/16/2003]
Old Jun 16, 2003 | 10:37 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Ac? (Corvettehumlan)
Is this a digital climate control or manual slider type? Are you talking about air speed or air temp? :cheers:
Old Jun 16, 2003 | 11:28 AM
Rich_01659's Avatar
Rich_01659
Dirty Condenser will do it, The low pressure switch could be failing. and the evaporator (located on the fire wall, passenger side) could be plugged/dirty. also, a full charge wil not help if the system was not evacuated properly befor the chargeing.
Old Jun 16, 2003 | 11:56 AM
ZylaRace's Avatar
ZylaRace
Default Re: Ac? (Rich_01659)
Typical & most common problem,... not enough refridgerant.
Old Jun 17, 2003 | 12:43 AM
Corvettehumlan
Its digital,airtemp on a -92.
To Ac?
