Cleaning Cooler?
Old Jun 18, 2003 | 12:50 AM
Corvettehumlan's Avatar
Corvettehumlan
Default Cleaning Cooler?
Whats the esiest way to get to the cooler to clean it(out side)?It is a LT-1 -92. :auto:
[Modified by Corvettehumlan, 6:01 AM 6/18/2003]
[Modified by Corvettehumlan, 6:02 AM 6/18/2003]
Old Jun 18, 2003 | 08:11 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Cleaning Cooler? (Corvettehumlan)
:cheers: Obviously you are talking about a "cooler" attached to the vehicle, not the cooler you fill with beer and throw in the back :smash:
Since there are several "coolers", which one are you talking about and what year is your vehicle?
:D :seeya
:steering:
[Modified by jackdaroofer, 8:12 PM 6/18/2003]
Old Jun 19, 2003 | 12:55 AM
Corvettehumlan
Default Re: Cleaning Cooler? (jackdaroofer)
Its a -92 LT-1.And know that U can get to the cooler and the AC-cooler from under but is there any ohter way?
Old Jun 19, 2003 | 01:19 PM
Z06_BluByU's Avatar
Z06_BluByU
radiator is what you mean... take off the top shroud, disconnect tranny/coolant lines, remove the 3 bastard bolts at the bottom of the shroud on both sides and presto.. pull it out..
although i found i had to remove the fans as well.. :steering:
Old Jun 19, 2003 | 02:12 PM
John Row's Avatar
John Row
Default Re: Cleaning Cooler? (BluByU)
...remove the 3 bastard bolts at the bottom of the shroud on both sides and presto.. pull it out..
:iagree: Those are bastards. I removed them from under the front by grabbing the ends with pliers till they were finger loose. I used plastic expansion fasteners to replace them with. Next time I'll just pop the fasteners loose.
I didn't need to remove the fans.
To Cleaning Cooler?
