Rear End Gear Question
Old Jun 18, 2003 | 01:19 PM
PsychoVetteOwner's Avatar
PsychoVetteOwner
Default Rear End Gear Question
I have a stock 89 Auto
and was wondering a few things
would a set of DANA23 3.54 gears fit in the stock housing that i have?
and also would this be a good switch
mind you, i haven't really done anything to the engine............................YET
Old Jun 18, 2003 | 01:24 PM
Zix's Avatar
Zix
Default Re: Rear End Gear Question (PsychoVetteOwner)
Yes, you should be able to get a set of 3.54 gearws for the D36, however, if you're going to do the swap it is recommended that you upgrade to the stonger D44 housing especially if you are going to be upgrading your engine later.
