door ajar lamp no work????
Old Jun 22, 2003 | 06:27 PM
The13Bats's Avatar
The13Bats
Default door ajar lamp no work????
Since I had to tear 85% of my dash apart today to get at the flashers I wanted to change the bulb for the "door ajar" warning but it still doesn't work the bulb is good I assume no signal is getting to it ...yea my doors are open....what I'm I missing all other warning lamps except "OD" work....
Thanks,
C.
Old Jun 22, 2003 | 09:34 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: door ajar lamp no work???? (The13Bats)
Maybe your door switch is sour?
Old Jun 23, 2003 | 12:50 AM
The13Bats's Avatar
The13Bats
Default Re: door ajar lamp no work???? (lou sylvestri)
Hum...the door pin switches work the dome lights just fine, I assumed that if the dome lights worked the dash door ajar should work, I wonder if it's a different curcuit....seems the c3's with door ajar has 3 pole pin switches....
:cheers: C.
Old Jun 23, 2003 | 08:14 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I believe there are 2 pin switches on each door !! :cheers:
Old Jun 23, 2003 | 10:50 AM
The13Bats's Avatar
The13Bats
Default Re: door ajar lamp no work???? (AGENT 86)
Ummmmm....I have seen one, under the top hinge, I will look much closer if there are two pin switches I wonder if the dash "door ajar" light is an option not standard.....hum.
:cheers: C.
Old Jun 23, 2003 | 11:00 AM
scorp508's Avatar
scorp508
The interior lights and the door ajar lights work on different switches. The interior lights use the white switch in the front door jam. Open a door and go to the rear edge of each door. You'll fine a small black round switch that might be stuck in on both sides. Get a small screwdriver and pop it out. Then squirt a little motor oil on it and push it in and out a few times to lubricate it.
I didn't even know I HAD a door ajar switch for the first 2 years I drove Fastguy's old car and saw his turn on. Then I found those switches.
p.s.
If you're wondering "why in the hell?" they did that... think about it. The back edge of the door moves a lot more than the inner door jam does. You want a door ajar switch to pickup a very small amount of movement and placing the switch in this location does so.
[Modified by scorp508, 11:01 AM 6/23/2003]
Old Jun 24, 2003 | 11:34 AM
The13Bats's Avatar
The13Bats
Default Re: door ajar lamp no work???? (scorp508)
p.s.
Yes, scorp I wonder why GM does alot of the things they do, in my case the black housing was there the plunger or center was gone, so what I did was remove the black housing and sawed the back half off, then fitted in a pin switch I happened to have from an old alarm set up, and reinstalled it, I noticed that the light would not come on unless the door was open, but went off with the door latched but not fully closed, "ajar"... it took a bit of adjustments but now my lights work when the door truely is "ajar"
Thanks, Charlie. :thumbs: :party:
PS, now to go post about the OD light.
Old Jun 24, 2003 | 11:36 AM
scorp508's Avatar
scorp508
Great, glad you got it figured out! :cheers:
To door ajar lamp no work????
