bbk Throttle body/tp sensor problem
Old Jun 25, 2003 | 05:24 PM
atotalnincompoop's Avatar
atotalnincompoop
Default bbk Throttle body/tp sensor problem
hello, i'm having a problem adjusting my Throttle positioning sensor after installing my new 58mm bbk throttle body. the sensor should produce .525 v at idle, I can't get anywhere near that, 4,5 v give or take.is what I'm getting.
I even went and bought a new sensor thinking that was the problem.
it wasn't what now????
thanks Greg :cheers:
Old Jun 25, 2003 | 07:07 PM
BAM92's Avatar
BAM92
Default Re: bbk Throttle body/tp sensor problem (atotalnincompoop)
I have heard of alot people having that problem with BBK. Some people had to modify theirs. They were not specific. Might have to go to adjustable tps that they have in mags and sometimes ebay. Did you call manufacturer and see what they said?
Old Jun 25, 2003 | 09:22 PM
lone73's Avatar
lone73
I take it this is on an '85 vette?
I have that style TB on my '73 but it's an OEM version. I also had trouble adjusting the voltage but mine would never go low enough. I ended up slightly adjusting the blades to get down to .5V. I don't know if the BBK has that adjustment capability but you might give it a try.
good luck
dr
Old Jun 25, 2003 | 10:11 PM
atotalnincompoop
thanks guys, it is an '85 :yesnod:
i tried BBK, their tech line is an email address that they will get back to you :confused: what kind of BS is that.
p.s. they don't even have an 800 number :mad
To bbk Throttle body/tp sensor problem
