ok i'm a little spacey tonight. the key is just basicly a resistor right? take a multimeter and read the ohms it should read my code right?
I'm just mad at the vette tonight it's left me stranded again. I want to order the VATS bypass before i put it off again.
thanks for any help
Re: VATS! how do you read your key code (eddieL98)
Not always...
My reading was in between #7 and #8 keycodes...2.10 k/ohms...I had a local locksmith with a GM VATS Interrogator check it; it was a #7. He had the blanks, too.
You can also make your own VATS bypass for a couple buck with resistors from Radio Shack and a soldering iron. If your interested I can post the info when I cet a chance, or you can e-mail me. Here's the codes and a brief description. http://www.asttraining.com/Files/vats1.pdf
Re: VATS! how do you read your key code (Marcho Polo)
guys, here's the post I made a long time ago on how to do this, but the images are broken on the post. I've got the images at home, so I'll update you guys with the images later today.
