LT1 Exhaust
Old Jun 27, 2003 | 11:31 AM
sundbergjc's Avatar
sundbergjc
Default LT1 Exhaust
Please tell what you all think of this idea. There are all sorts of after market exhaust systems available for an LT1 for $700 to $1000 or more. It appears to me that most of them simply remove the big cat in the center and then fool around with the mufflers. Why not just replace the center Cat with straight pipes and keep the stock mufflers? Mine is a 95. Sure would save some money. Anyone tried this approach?
Old Jun 27, 2003 | 11:39 AM
SSLT1KID's Avatar
SSLT1KID
Default Re: LT1 Exhaust (sundbergjc)
after market exhaust somethimes are larger diameter, and the bends and mufflers are less restrictive than stock. thats not a bad idea for a cheap quick mod, tho. im not sure what that would do to smogability.
Old Jun 27, 2003 | 11:45 AM
John Row's Avatar
John Row
The big "cat" in the middle is a resonator. Stock it does a lot to reduce the resonnance you hear in passenger compartment with after market exhausts.
If you remove it and replace it with straight tubes, you'll probably end up with various RPMs that will blur your eyes.
It would be a cheap experiment. Just don't trash the stock resonators until after a good test run.
Old Jun 27, 2003 | 11:46 AM
sundbergjc's Avatar
sundbergjc
Default Re: LT1 Exhaust (SSLT1KID)
Well on smogability, I imagine all the after markets systems will fail because the cat is gone. As to the stock mufflers, there are plently of after market free flow jobs out there.
Old Jun 27, 2003 | 12:21 PM
John Row's Avatar
John Row
The cats are the large round items between the exhaust manifolds and the resonators.
Removing the resonators won't affect smog unless you have some sort of visual inspection that requires stock exhaust.
Old Jun 27, 2003 | 01:04 PM
sundbergjc's Avatar
sundbergjc
Default Re: LT1 Exhaust (John Row)
So I guess the big center one is a resonator and not a CAT (makes me wonder why the others are called pre-cats). Anyway, given this, my idea may result in some not so pleasant noises inside. Oh well. Thanks. :cheers:
Old Jun 27, 2003 | 01:27 PM
John Row's Avatar
John Row
Some of the L98s had pre-cats just prior to a single main cat.
LT1 went with dual cats for higher flow.
Old Jun 27, 2003 | 02:43 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
:withstupid: LT1s don't have pre-cats
L98s have 3 cats - 2 pre-cats, 1 main cat, and 2 mufflers
LT1/4s have 2 cats (in the same place as the L98s pre-cats) a center resonator (which is essentially another muffler in the same place as the L98s main cat) and 2 mufflers
L98s have a front and rear Y-pipe whereas the LT1/4 are dual from headers into the resonator and then dual again out :D
Old Jun 27, 2003 | 02:55 PM
HammerDown's Avatar
HammerDown
Since I've already gone through all of this myself, I'll tell you what I think you should do.
Take the car to a muffler shop and have them cut off the stock mufflers (but make sure to tell them you might reuse them), and have them weld in straight pipes in their place. Tell them to reuse the stock tips. Also, make sure they use pipe that is the same diameter as the rest of the pipe in the system (2.75"). This is a fairly cheap thing to do, around $60, and it will sound like a totally different car. Remember, you will still have two cats and a resonator in the exhaust path, so it's not as loud as one would think. And I actually had LESS resonance with this setup than I do with my Flowmasters. You could also ask the shop about putting in an H pipe before the resonator to smooth out the popping and gurgling a bit. All in all, this will be MUCH cheaper than even just buying two aftermarket mufflers, and since you are undecided, it's probably the best way to experiment.
Old Jun 27, 2003 | 02:59 PM
_freakmonkeydogboy_
Default Re: LT1 Exhaust (HammerDown)
:iagree: the "muffler eliminators" are nice, but with an auto, i lost low-end torque (i.e. not as much uummph off the line) and have since replced that w/ a borla cat-back and it is like night and day. i regained my lost torque and kept the same sound as the elims, the best of both worlds and i gained a stainless steel exhaust system that should hold up for a long time, now all i need is long tube headers and an x-pipe :reddevil
Old Jun 27, 2003 | 03:11 PM
bogus's Avatar
bogus
Default Re: LT1 Exhaust (_freakmonkeydogboy_)
I didn't like the overall effect of the elims... they did kill low end torque, and were super boomy in the interior cabin.
Last summer, I installed Corsa's after nearly failing with eliminators with resonator tips!!!!!!!!
The Corsa's ROCK. I also got torque back!
There is more to exhaust design than just getting them out of the engine... it's something of a black art. I know the concept, I just don't know how they arrive at it.
Old Jun 27, 2003 | 04:33 PM
LT4 2 Fast's Avatar
LT4 2 Fast
Default Re: LT1 Exhaust (bogus)
I know this is kindda off the question posted, but does any one have any input on how Corsa's sound with no cats and long tube headers? I have the power pulse on my LT4 and I'm about to purchase headers and wonder how the Corsa's sound with them. Is it louder? How bout the resonance?
Old Jun 27, 2003 | 04:51 PM
sumoboy's Avatar
sumoboy
On the 95 doesn't the center resonator have two separate pipes through it since it's suppose to be true duals? I remember someone was going to gut it thinking it was a cat and found out it was two pipes.
http://forums.corvetteforum.com/zerothread?id=197777 :thumbs:
[Modified by sumoboy, 5:09 PM 6/27/2003]
Old Jun 27, 2003 | 05:16 PM
John Row's Avatar
John Row
Default Re: LT1 Exhaust (sumoboy)
On my 94 it was 2 perforated pipes inside the outer shell. The pipes were straight through with some indents along the way.
The PE had similar construction only without the indents.
Old Jun 27, 2003 | 06:06 PM
tjwong's Avatar
tjwong
The stock 95 uses a center resonator and two mufflers at the rear. The GM resonator is a true 2.75" dual core resonator that is of decent design. Sometime ago when I first installe a Borla system it consisted of 2.5" pipe and the center resonator was a 2.5" as well, the factory tubing was 2.75". Other than it had restrictive mufflers the best bet is to just replace the rear mufflers with some 2.75" inlet Magnaflows. I think now Borla has a 2.75" system so the cheap way to go is to just replace the rears with a set of high flow mufflers.
Unless you are like me with a 396 LT4 and a blower a 2.75" straight through system would be more than adequate. I am running a new B&B 3" system with an H pipe as their resonator necked down to 2.5" in their internal resonator core. It also has an internal H pipe built into to it.
Old Jun 27, 2003 | 10:35 PM
fiberglasscoffin's Avatar
fiberglasscoffin
my texas exhaust kind of does what you are talking about the 1 resonator in the middle gets junked and a new muffler gos there and you do away with the rears sounds great and the quality is the best and i got 4 or 5 tenths from this alone in the 1/4
Old Jun 27, 2003 | 11:02 PM
vette92_1's Avatar
vette92_1
I did exactly that, until I saved a few more bucks and replaced the stock mufflers with some dynomax super turbos.
I did run it for a month or 2 with just the resonator replaced with 2 straight pipes and the stock mufflers. I think the gain was very minimal, it did seem to have a little more in the upper rpm range. It actually felt like a bigger gain was acheived when I replaced the stock mufflers with the dynomax's. But I think if I had to do over again, I would have replace the mufflers with Magnaflo's instead of the dynomax's. I think I got the gain in flow I wanted with the Dynomax's, but they are not near loud enough for me. It's barely louder than stock.
I think for an exhaust system on a "budget" it's the way to go.
But I think if you have got the money, one of the SS cat-back systems is the way to go. To many good reviews on this forum to ignore it. Just my .02
To LT1 Exhaust
