Caution for Camber Brace Installers
Old Jul 2, 2003 | 10:37 PM
96GS#007's Avatar
96GS#007
Default Re: Caution for Camber Brace Installers (Strick)
Here are two pics of the three-piece C/B for the LT1/4 with the electric water pump. I paid extra for the red. Standard color is black.
VERY easy to install and worth every nickel.
Old Jul 2, 2003 | 10:41 PM
Strick's Avatar
Strick
Default Re: Caution for Camber Brace Installers (96GS#007)
Now I'm starting to breathe heavy. I like the red! Is it powder coated red?
Old Jul 2, 2003 | 10:50 PM
96GS#007's Avatar
96GS#007
Yes, it's powder coated. :thumbs:
Old Jul 2, 2003 | 10:55 PM
Strick's Avatar
Strick
Now you've done it. Time to break out the plastic! :skep:
Old Jul 2, 2003 | 10:59 PM
4GTWRK's Avatar
4GTWRK
Well Dave, Thanks for the come back. Just to let you know, my first job was with Smittys Shell on Westport Ave in Norwalk, CT, back when a dollar's worth got you 3.2 gallons. How's that for dating myself?! :eek:
I have a 92 LT-1 with the HD Meziere water pump. Any problem with this? Send me the particulars please, and could you send/fax me some instructions so I can see what I'm in for? Thanks man. :chevy
I can remember those days, they were GREAT! :cheers:
My first car only got 6 miles to the gallon and 5 bucks went a long way :yesnod:
I'll send you an email with the installation info.
Dave :seeya
Old Jul 2, 2003 | 11:03 PM
STL94LT1's Avatar
STL94LT1
Default Re: Caution for Camber Brace Installers (84c4)
Looks like we got another "Camber-Brace" convert. :D
Old Jul 2, 2003 | 11:07 PM
Strick's Avatar
Strick
Thanks Dave, My 57 Chevy got gallons per mile, but that was because of my heavy foot and the need for speed. One of these days I'll grow up...................................... ........................Nah.
Old Jul 2, 2003 | 11:10 PM
Strick's Avatar
Strick
Default Re: Caution for Camber Brace Installers (STL94LT1)
Hey STL, Do you get a commission? :skep:
Old Jul 2, 2003 | 11:14 PM
STL94LT1's Avatar
STL94LT1
Yeah Dave, what about a commission?
Only thing is, I probably still owe Dave for installing both of my Camber-Braces.
Old Jul 2, 2003 | 11:20 PM
Strick's Avatar
Strick
How much did he charge for the install? What is involved? Do I have to remove anything off the front of the engine? Please say no. I've had it all off twice this spring. What a minute, did you say both of your braces? I thought there was only one :confused:
Old Jul 2, 2003 | 11:30 PM
STL94LT1's Avatar
STL94LT1
Dave didn't charge for the installs. In fact he didn't even charge me for the second Camber-Brace. Dave used my car to build the prototype electric water pump Camber-Brace.
From watching Dave do the install it looks like the electic water pump C/B is a bit easier to install than the original, no twisting or turning. Either way neither Camber-Brace is very hard to install.
Old Jul 2, 2003 | 11:42 PM
Strick's Avatar
Strick
Thanks for all your info. I'll be ordering tomorrow, if I can sneak that plastic away from my wife :lol: :lolg: :rofl: :skep:
Old Jul 2, 2003 | 11:44 PM
  #33
Strick's Avatar
Strick
Hey Jimmy, thanks for the use of your post :yesnod:
You see it's all your fault.
Old Jul 3, 2003 | 12:18 AM
  #34
Gary04Z06's Avatar
Gary04Z06
:hurray:
Old Jul 3, 2003 | 12:21 AM
  #35
atotalnincompoop's Avatar
atotalnincompoop
Default Re: Caution for Camber Brace Installers (JimmyS5600)
good tip :cheers:
Old Jul 3, 2003 | 12:24 AM
  #36
Strick's Avatar
Strick
Default Re: Caution for Camber Brace Installers (Gary96LT4)
I feel like I've just had the full court press. :crazy:
Old Jul 3, 2003 | 08:45 AM
  #37
Atok's Avatar
Atok
Default Re: Caution for Camber Brace Installers (Rich B.)
...Nova Scotia???...Isn't that the strange island where time is always a half-hour off??? :D
Close! You're talking about Newfoundland....the "Rock". :D
To Caution for Camber Brace Installers
Old Jul 3, 2003 | 08:54 AM
  #38
Atok's Avatar
Atok
Strick, get the Camber-Brace, you won't be disappointed.
Ok, I've been following this thread and looking at my upper control arms. My Vette ('95) has a cross-member just in front of the upper control arms. It's a fairly substantial chunk of steel. It would seem that this cross-member would stiffen the frame horns enough to eliminate any twisting from control arm forces.
If the camber brace makes so much difference where does it bolt? What does it stiffen?
:cheers:
Old Jul 3, 2003 | 09:43 AM
  #39
4GTWRK's Avatar
4GTWRK
Default Re: Caution for Camber Brace Installers (Atok)
Atok,
The brace that you are referring to is made from formed sheet metal and more or less and acts as a frame rail spacer. The Camber-brace bolts to the upper control arm frame horns to provide maximum leverage to prevent the cross-member from flexing.
Check out our web site for more details and pictures. http://www.r-dracing.com
Dave :seeya
[Modified by 84c4, 8:44 AM 7/3/2003]
Old Jul 3, 2003 | 10:34 AM
  #40
NavyVet's Avatar
NavyVet
Atok - like Ron said. I am a 2-time customer. I race both cars extensively. You will definitely notice the difference. The single best "bang for the buck" I've found to improve handling for AX and road course events. And, I've tried most everything - heim joints, poly, lowering, different bars, etc. All those things made improvements, but none made as significant a difference for one change as the Camber Brace. When I got my 2nd C4, the first thing I did was call Ron for a Camber Brace...... Then I washed it. :flag
