Idle problems, IAC counts ??
Old Jul 7, 2003 | 03:49 PM
Fast_vette89's Avatar
Fast_vette89
Default Idle problems, IAC counts ??
Ok, My 89 Auto idles fine, half the times, the other times it will just idle up to 1,500rpm for no dam reason. and maybe it will go back down... in 10sec, or 10hrs.... so i have a intermitent idle problem. I've replaced the IAC motor, and the TPS motor, and I've even done a 730SD swap and nothing did help the idle. I've adjusted the TPS voltage....everything. checked for vacum leaks... I'm done.... any ideas????? I hooked up my scanner and with the coolant around 180 in Park, my IAC counts were 30, 40's, and 70's, i even saw over 100. but mainly in the 50's after being adjusted. That normal. how should i set the IAC count????
Old Jul 7, 2003 | 09:28 PM
zwede's Avatar
zwede
Default Re: Idle problems, IAC counts ?? (Fast_vette89)
I guess scan it while it has the problem and idles high. Check IAC counts. If they are low you have air entering somewhere. Either a vacuum leak or sticking throttle. If the counts are really high maybe a sensor out of whack?
Old Jul 8, 2003 | 01:50 PM
Bluevette85's Avatar
Bluevette85
Check all the plastic vacuum lines for cracks. The EGR valve could also be leaking. You said you replaced the IAC but did you clean the IAC passage?
Old Jul 8, 2003 | 06:13 PM
72tccracer's Avatar
72tccracer
Default Re: Idle problems, IAC counts ?? (Bluevette85)
What is low or no counts an indincation of? And what type of counts should you see?
Chuck
To Idle problems, IAC counts ??
