engine miss and then quit...possible opti?
Old Jul 9, 2003 | 12:10 AM
Slick94's Avatar
Slick94
Default engine miss and then quit...possible opti?
Started out for dinner tonight with club members and after 5 miles it started to miss. As I pulled over it died. Sat for a minute and restarted with no miss. Drove it home and in the garage, took the Aztek to dinner. Sounds like the saga of the 92-94 opti-spark. Is Jeff the best for prices? How much time should it take? :sad:
While I'm at it would it be wise to change the plugs and wires? What would be the best to put in? Thanks for the advise.
[Modified by Slick94, 7:23 PM 7/9/2003]
Old Jul 9, 2003 | 09:48 AM
ittlfly's Avatar
ittlfly
Default Re: engine miss and then quit...possible opti? (Slick94)
You can check around, but I think you will find that Jeff (Chris) has one of the lowest prices on OEM. YOu could probably do it in a few hours if everything goes exactly right and you have the proper tools. I figureded on a weekend and 2 six packs. :D It took about 8 hrs as I took my time.
Oh yea, I also replaced my water pump, while I was in there. At least change the water pump and opti seals in the timing cover. Good insurance.
Old Jul 9, 2003 | 06:23 PM
Slick94's Avatar
Slick94
Default Re: engine miss and then quit...possible opti? (ittlfly)
Thanks for the info on the seals. I was wondering if I should replace the water pump. Figure it would be the next to go and ruin a new opti.
Old Jul 9, 2003 | 06:44 PM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Cruise-In VI Veteran
Look at your fuel pump as well!!
Old Jul 9, 2003 | 07:48 PM
Strick's Avatar
Strick
Here is something else to look at http://www.corvetteclinicinc.com look under C-4 solutions. I had him vent my brand new opti for about $100. Probably too high, but I wanted it right and he did a nice job. Most guys that vent now, use a 95-96 cap on a 92-94 distributor base. The 95-96 cap has the vent tube on it. Check all the easy stuff first, then think about the opti.
Old Jul 9, 2003 | 11:45 PM
Slick94's Avatar
Slick94
Thanks for the input guys. Guess I'll order the parts tomorrow. Still would like input on brand of plugs and wires.
Old Jul 10, 2003 | 11:16 AM
vvv90's Avatar
vvv90
Default Re: engine miss and then quit...possible opti? (Strick)
Bad idea. The whole Opti replacement for 92-94 is $330, then the rebuild kit with cap is another $200. Save $200 and just mod the new cap. It only takes an hour or two.
Old Jul 10, 2003 | 12:55 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
In addition to the water pump inspection, I'd replace the wires and plugs, too. It's all relevant labor while your in there and added peace of mind down the road. I used AutoLite Platinum plugs and O.E.M. wires.
[Modified by onedef92, 12:55 PM 7/10/2003]
Old Jul 10, 2003 | 01:50 PM
STL94LT1's Avatar
STL94LT1
Taylor Spiro-Pro 8mm wires/Denso Iridium plugs.
Old Jul 10, 2003 | 02:23 PM
Strick's Avatar
Strick
I used NGK Iridiums and MSD Super Conductor Wires. Taylors are good, too. The plug for my 92 LT-1 is TR55IX, a little pricey, but they work fine. Stay away from the AC Delco Professional Platinums as someguys have had the platinum pucks fall off. Checkout the Tech Tips for some guidance on the job.
Old Jul 11, 2003 | 08:47 AM
Slick94's Avatar
Slick94
Thanks for all the help. I have a new opti, water pump, hose kit and seals on order from Superior. I'll get the wires and plugs locally. I should have the parts next week sometime.
Old Jul 11, 2003 | 11:16 AM
vvv90's Avatar
vvv90
BTW: Once you've removed the hoses and water pump. plugs and wires are not nearly as hard as they look.
ONLY, if you remove the driver's side fender. It's only about 6 bolts, takes 5 minutes to remove, and you can get to every plug with a socket/ratchet and 3" extension.
:cheers:
Old Jul 12, 2003 | 11:11 AM
Alchemist's Avatar
Alchemist
NC Events Coordinator
I used NGK Iridiums...
Same here...with Moroso 8mm wires.
Stay away from the AC Delco Professional Platinums as someguys have had the platinum pucks fall off...
AMEN!!! When i put the NGKs in last month...three pucks were "missing" from the Delco PPs i took out! :eek:
Old Jul 13, 2003 | 12:52 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Have you checked your fuel pump pressures???????
When was the last time you changed you fuel filter??????
Just one of my simple thoughts....
Good Luck
tony
:flag
Old Jul 14, 2003 | 09:34 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: engine miss and then quit...possible opti? (oldace84)
I called a dealer just to see how much I was saving over Mid-America's price on the cap and rotor $150
Dealer prices
$213 cap and rotor :eek:
$275 waterpump :eek: :eek:
Just for grins I call Autozone and got
$120 cap and rotor
$133 waterpump ( new not rebuilt )
:cheers:
Old Jul 15, 2003 | 12:02 PM
vvv90's Avatar
vvv90
Default Re: engine miss and then quit...possible opti? (BrianCunningham)
I called a dealer just to see how much I was saving over Mid-America's ...
Are you doing Opti work because you're having problems??? Or are you just doing maintenance???
I wouldn't mess with a rebuild considering it's the optical pickup that tends to go bad, not just the cap and rotor. If you find any rust in there I wouldn't mess around and just buy new from Superior @ ~$330. Replace it once and forget about it.
P.S. Make sure you put Black RTV around the cap gasket and electrical connection! :cheers:
Old Jul 15, 2003 | 01:43 PM
Fuzzy Dice's Avatar
Fuzzy Dice
I have Moroso wires and Rapidfires in mine...no problem's..good luck
To engine miss and then quit...possible opti?
Old Jul 15, 2003 | 01:48 PM
John Row's Avatar
John Row
Default Re: engine miss and then quit...possible opti? (vvv90)
...I wouldn't mess with a rebuild considering it's the optical pickup that tends to go bad, not just the cap and rotor. If you find any rust in there I wouldn't mess around and just buy new from Superior @ ~$330. Replace it once and forget about it.
P.S. Make sure you put Black RTV around the cap gasket and electrical connection!...
:iagree:
Plus bearing and seals fail as well. Replace it.
[Modified by John Row, 10:49 AM 7/15/2003]
Old Jul 15, 2003 | 01:53 PM
BrianCunningham
Problems, it misses like crazy.
I can't load it about 2,000rpm
The wire and plugs are recent.
No underhood light show.
I don't think it's water.
I've got an oil leak at the front of the engine.
Hoping it's the waterpump drive so I dont' have to pull the balancer.
Assuming, I know bad idea :rolleyes:, you can change the waterpump drive seal w/o pulling the timing cover.
Old Jul 15, 2003 | 02:05 PM
vvv90's Avatar
vvv90
Yes you should replace your Opti and Waterpump timing chain cover seals anyway. It's cheap insurance. Just make sure you're gentle and use a tool to put the waterpump seal on. Do a search for procedures. The Opti seal simply presses into the cover but you have to make sure the lip is not folded over the input shaft of the Opti unit or you'll get a nasty oil leak. IM me your email and I'll send you a copy of my Opti replacement guide. You won't have to vent yours but you can pick through the guide for tips.
If you have hestation on load then that IMHO means there's something wrong with your optical pickup and it might no be able to advance your timing appropriately. I could be wrong, but there's no way it's just the cap and rotor.
I too didn't think I had water but wait until you take a look behind your waterpump and inside your opti before you come to a conclusion. I had scale running out the back seal on the opti which is a clear sign.
Don't mess around! Just replace the Opti. Yours sounds like it's in even worse shape than mine was and when I opened mine everything was covered in rust.
:cheers:
