trouble code help
Old Jul 16, 2003 | 04:36 PM
atotalnincompoop's Avatar
atotalnincompoop
Default trouble code help
i can't find my manual to read what these codes mean so maybe you can help
1. 4 flashes then 2 flashes
2. 4 flashes then 4 flashes
thanks guys Greg :cheers:
Old Jul 16, 2003 | 05:11 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: trouble code help (atotalnincompoop)
42 = Electronic Spark timing circuit (85 to 91)
44 = Lean exhaust present
Old Jul 16, 2003 | 05:15 PM
atotalnincompoop
Default Re: trouble code help (Steel Blue 91)
thanks is that all that it says about them?
does it say what to look for?
Old Jul 16, 2003 | 05:19 PM
scorp508's Avatar
scorp508
Did you set your timing recently? Make sure you remembered to plug your EST wire back in if you have. If it IS plugged in unplug the ECM 12v plug for 1 minute and plug it back in.
Old Jul 16, 2003 | 11:11 PM
atotalnincompoop
what would cause a lean exhaust condition?
To trouble code help
