Installing a Hurst
Old Jul 16, 2003 | 05:41 PM
yellowc4LH's Avatar
yellowc4LH
Default Installing a Hurst
I ordered the hurst shifter last night. I wanted to know if ya'll could help me out. I have heard that it is a pita to install. Is there a website that has instructions or anything else that can help me out with the installation? Help would be appreciated. Thanks
Old Jul 16, 2003 | 06:59 PM
luvmy92's Avatar
luvmy92
Default Re: Installing a Hurst (yellowc4LH)
Scroll down to Hib's review...
https://www.corvetteforum.com/review...406&TopicID=21
Mike
Old Jul 17, 2003 | 12:47 AM
C4DC's Avatar
C4DC
St. Jude Donor '06
I got the car up on 4 stands, removed the exhaust and the job was mostly straight foreward. That inner rubber boot can be a challenge to reinstall. Shift **** key can also be a pita. Some didn't remove the exh. but i'm glad I did...
Old Jul 17, 2003 | 07:48 AM
Strick's Avatar
Strick
You are really going to like this shifter. I put one in recently and it is the most enjoyable upgrade I've made to my Vette. What helped me out was the Helms Service manual and the Hurst instructions, combined. I, also, had to replace the lower boot as the previous owner had cut it off when replacing the clutch :U The hardest part was removing the pin from below. Mine was easy, but some guys report that theirs was a PITA. I did remove the exhaust and X-brace (vert). While you have the exhaust off, REPLACE YOUR FUEL FILTER It's easy to get at. :flag :flag :flag
To Installing a Hurst
