My 86 is idling high betweek 10-11 RPM. This just started. It use to idle between 6-7 rpm. I sprayed some WD40 on the linkage & cable but it didn't help. Is there an easy way to adjust the idle?
You could have a vacuum leak. Check all the hoses and the black plastic vacuum lines that go under the plenum. They become brittle and break with age and heat. Is your IAC working? Try resetting it.
A/C is working. Just coverted to R134.
When I first start the car the compressor clutch click on for a second and moves a 1/4 turn. This happens every minute or so. Is this normal?
A/C is not on at the time.
If you don't have a vacuum leak, pull the IAC motor from under the TB and clean the pintel and it's bore. Then reset base idle with the method on my site.
IAC is Idle Air Control valve. It is screwed into the bottom of the throttle body and lets a controlled amount of air in to adjust the idle. It has a 4 pin connector on the passenger side of the throttle body. Read this tech tip for information: https://www.corvetteforum.com/techti...D=55&TopicID=2
