oil pressure
Old Jul 20, 2003 | 03:36 PM
adam182003's Avatar
adam182003
Default oil pressure
hey i was wondering about what oil preasure every one elses vett runs at at an idle i have an 85 l98 and it seems to be high like 65 to 70 that just seams high to me at an idle. i also havnt drivin it in about 2 years and i dont rember what it was at before i took it off the road and put it away
Old Jul 20, 2003 | 05:07 PM
vader86's Avatar
vader86
Default Re: oil pressure (adam182003)
It should be 45-60psi at cruise, and about half of that at idle.
Check your sending unit, its a fuel filter-looking thing stuck to the back of the intake manifold, behind the distributor and below the wiper motor. I suspect yours is bad if youre getting those readings at idle.
Old Jul 20, 2003 | 05:15 PM
adam182003's Avatar
adam182003
Default Re: oil pressure (vader86)
how do i know if it is bad? and its it a pain to get out? :confused:
Old Jul 20, 2003 | 05:19 PM
vader86's Avatar
vader86
From what ive been told and figured out recently, its impossible to tell whether it or the pump are bad without replacing one. The sender is cheap, like $16 at Advance, so replace it first.
Its a bitch to get at.
Run a search, I had a thread on this very subject last week.
Old Jul 20, 2003 | 05:29 PM
scorp508's Avatar
scorp508
Are those readings at a cold or hot idle?
To oil pressure
