LT-1 ECM Codes?
Old Jul 20, 2003 | 06:21 PM
Yellow C-4's Avatar
Yellow C-4
Default LT-1 ECM Codes?
On a long drive recently, I got a service engine soon light after driving about an hour. There were no apparent problems...engine continued to run great. The light stayed out when the car was stopped and restarted, and didn't come on the whole rest of the day. Same thing happened on the drive home the next day.
I had a little trouble downloading the ECM codes. Although it's a '92 LT 1, an earlier owner appears to have replaced the ECM, maybe with something newer ('94 or '95). Here's the codes I finally got:
Module 1: H72, H74, ---
Module 4: H32, ---
Module 9: ---
Anyone have a clue what I have going on here? How do I reset the ECM?
Old Jul 20, 2003 | 06:28 PM
don hall's Avatar
don hall
Default Re: LT-1 ECM Codes? (Yellow C-4)
http://www.c4vettes.com/ecm.htm
Old Jul 20, 2003 | 06:35 PM
Lone Ranger's Avatar
Lone Ranger
Choices:
1. Disconnect negative battery terminal and let sit for a few
2. Pull fuses for ECM
3. Follow procedure in the link in Oldman's post.
[Modified by Lone Ranger, 5:36 PM 7/20/2003]
Old Jul 20, 2003 | 06:42 PM
Yellow C-4's Avatar
Yellow C-4
I tried that website...I guess the "H32" is the same a "32" or EGR problem, but how about the others? "H72" (72) says gear shift problem (which doesn't sound right) and "H74" isn't listed.
Old Jul 20, 2003 | 09:15 PM
Lone Ranger
H72 is vehicle speed sensor loss. But hold on... now where'd I put that file... shoot. Its on my other PC. Standby while I go find it.
Old Jul 20, 2003 | 09:22 PM
Lone Ranger
Found it. I don't know why some #'s are skipped, and I forgot where I got this data from, but hopefully it will assist some:
DIAGNOSTIC TROUBLE CODES 1994 TO 1996:
DTC #11: Malfunction Indicator Lamp Circuit.
DTC #13: Bank #1 Heated Oxygen Sensor #1 Circuit:
DTC #14: Engine Coolant Temperature Sensor Circuit Voltage Low.
DTC #15: Engine Coolant Temperature Sensor Circuit Voltage High.
DTC #16: Distributor Ignition System Low Pulse.
DTC #18: Injector Circuit.
DTC #21: Throttle Position Sensor Circuit Voltage High.
DTC #22: Throttle Position Sensor Circuit Voltage Low.
DTC #23: Intake Temperature Sensor Circuit Voltage High.
DTC #24: Vehicle Speed Sensor Circuit.
DTC #25: Intake Air Temperature Sensor Circuit Voltage Low.
DTC #26: Evaporative Emission Canister Purge Solenoid Valve Circuit.
DTC #27: EGR Vacuum Control Signal Solenoid Valve Circuit.
DTC #28: Transmission Range Pressure Switch Assembly Fault.
DTC #29: Secondary Air Injection Pump Circuit.
DTC #32: Exhaust Gas Recalculation.
DTC #33: Manifold Absolute Pressure Sensor Circuit High.
DTC #34: Manifold Absolute Pressure Sensor Circuit Low.
DTC #36: Distributor Ignition System High Pulse.
DTC #37: Brake Switch Stuck On.
DTC #38: Brake Switch Stuck Off.
DTC #41: Ignition Control Circuit Open.
DTC #42: Ignition Control Circuit Shorted.
DTC #43: Knock Sensor Circuit.
DTC #44: Bank 1 LF Heated Oxygen Sensor #1 Circuit Lean.
DTC #45: Bank 1 LF Heated Oxygen Sensor #1 Circuit Rich.
DTC #47: Knock Sensor Circuit Or Module Missing.
DTC #48: Mass Air Flow Sensor Circuit.
DTC #50: System Voltage Low.
DTC #51: EEPROM Programming Error.
DTC #52: Engine Oil Temperature Sensor Circuit Voltage Low.
DTC #53: System Voltage Low.
DTC #55: Fuel Lean Monitor.
DTC #58: Transmission Fluid Temperature Sensor Circuit Low.
DTC #59: Transmission Fluid Temperature Sensor Circuit High.
DTC #62: Engine Oil Temperature Sensor Circuit Voltage Low.
DTC #63: Bank 2 RF Heated Oxygen Sensor #1 Circuit Open.
DTC #64: Bank 2 RF Heated Oxygen Sensor #1 Circuit Lean.
DTC #65: Bank 2 RF Heated Oxygen Sensor #1 Circuit Rich.
DTC #66: A/C Refrigerant Pressure Sensor Circuit Open.
DTC #67: A/C Pressure Sensor Circuit Sensor or A/C Clutch.
DTC #68: A/C Relay Circuit.
DTC #69: A /C Clutch Circuit.
DTC #70: A/C Clutch Relay Driver Circuit.
DTC #72: Vehicle Speed Sensor Loss.
DTC #73: Pressure Control Solenoid Circuit Current Error.
DTC #74: Traction Control System Circuit Low.
DTC #75: Transmission System Voltage Low
DTC #77: Primary Cooling Fan Relay Control Circuit.
DTC #78: Secondary Cooling Fan Relay Control Circuit.
DTC #79: Transmission Fluid Overtemp.
DTC #80: Transmission Component Slipping.
DTC #81: Transmission 2-3 Shift Solenoid Circuit.
DTC #82: Transmission 1-2 Shift Solenoid Circuit.
DTC #83: Torque Converter Solenoid Voltage High.
DTC #84: 3-2 Control Solenoid Circuit.(Auto Only).
DTC #84: 2nd And 3rd Gear Blockout Relay Control Circuit.
DTC #85: Transmission TCC Stock On.
DTC #90: Transmission TCC Solenoid Circuit.
DTC #91: One To Four Upshift Lamp(Manual Only).
DTC #97: VSS Output Circuit.
DTC #98: Tachometer Output Signal Voltage Wrong.
Old Jul 20, 2003 | 11:59 PM
Yellow C-4's Avatar
Yellow C-4
Default Re: LT-1 ECM Codes? (Lone Ranger)
Thanks. Sounds like I might have had an intermittant power problem...I can't imagine all those unassociated codes happening at the same time. I think I'm going to clear them and see if it happens again. (I saved that list for future reference.)
To LT-1 ECM Codes?
