C4 front brakes.....
Old Jul 20, 2003 | 07:02 PM
yak driver's Avatar
yak driver
Default C4 front brakes.....
My C4 has 230,000 km's on, still love driving it. Latest problem is the front brakes. The brake calipers have two guide pins that go into the mounting braket attached to the spindle. The mounting bracket holes are worn oversize, so the calipers have too much play. Brakes rattle, and all that stuff. GM doesn't support the mounting bracket, I don't want to "re-invent the wheel" Any suggestions?
I've got the stock wheels that I'm not changing (spent 2 days with them on a lathe getting them super shinny). I've tried used mounting brackets, but they ended up being just as worn as mine. I don't want to put used parts on the car. Anybody upgraded to the '88 or later brakes? Is it a big deal, or can I just bolt the stuff on?
I'm not a racer or hard driver, just enjoy the car.
Old Jul 20, 2003 | 07:18 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: C4 front brakes..... (yak driver)
:cheers:
You intorduced a major qualifer, you don't want to change wheels!
The C5 front brake system is a great add on for somewhere around $ 600. But you will likely have to change wheels or add off sets
The J55, the larger brake C4 option may be available to you without having to change wheels.
Suggest you contact someone like Superior Chevrolet or The Last Detail to see what's available
:seeya
:steering:
[Modified by jackdaroofer, 7:19 PM 7/20/2003]
Old Jul 20, 2003 | 08:08 PM
GusBustamanteJr's Avatar
GusBustamanteJr
Default Re: C4 front brakes..... (jackdaroofer)
You can go with any brake system you like if you put in a wheel spacer. The cheapest bet would be to buy new stock C4 calipers and brackets.
Old Jul 20, 2003 | 08:30 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
:cheers: Just thought of something, i have perfectly good vrackets, calipers, roters and pads I took off my 88 C4 when I upgraded to C5
I was thinking of putting them on the back, but have since changed my mind.
If you are interested, let me know
System had less than 100K when i switched
:seeya
:steering:
Old Jul 20, 2003 | 09:19 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
If I understand this correctly, you're saying G.M. doesn't offer new caliper brackets or guide pins for your year?
And you wanna hang on to your stock rims right? You're gonna need to find a source for new bkts, or check into the J55 upgrade for you're year. I'm not sure that 16" rims will allow for that upgrade. But someone here should know for sure.
Good luck.
Old Jul 21, 2003 | 06:42 PM
yak driver's Avatar
yak driver
Default Re: C4 front brakes..... (edsalinas)
thanks guys,
GM still supports the calipers, guide pins ( I relaced the guide pins, but it didn't help), but NOT the mounting brackets. I have not been able to find a new replacement bracket.
So the question would be, will the J55 brakes go on stock '87 wheels. Where would I go about finding that info??
Old Jul 21, 2003 | 07:11 PM
Ray383's Avatar
Ray383
thanks guys,
They will only fit if you have 16x9.5 rims
Old Jul 21, 2003 | 08:04 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Have you checked these guys out?
http://www.specialtyholdingsltd.com/
They are in Kamloops
:cheers:
I forgot to say welcome to the forum :seeya
[Modified by AGENT 86, 5:04 PM 7/21/2003]
Old Jul 21, 2003 | 08:08 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I’m not sure about 87, but my 91 has spring clips on lower part of the brake pads to keep them from moving.
Old Jul 22, 2003 | 01:12 AM
yak driver's Avatar
yak driver
Default Re: C4 front brakes..... (We Gone)
I'm pretty sure I've got the 9.5x16 rims, I seem to remember the tire guy saying something about that when I put tires on it a couple years ago.
Sounds like the J55 is going to be the way to go. I just hope the mounting brackets etc, bolt on to the spindle without problems.
Once again, thanks for the info.
Great forum
Old Jul 22, 2003 | 03:21 AM
akisana's Avatar
akisana
I think we are having the same problem. The rattling is very nagging. I notice though that I had some play between the outside caliper and the brake pad. I'm not sure if that's causing the rattling or if it's the guide pin being worn out. someone on the board suggested I check for the anti-rattle clip on the pads and mine were gone. I'll replace them and see. keep us posted.
'89 auto coupe
To C4 front brakes.....
