86 Main cooling fan problem
Old Jul 22, 2003 | 12:58 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default 86 Main cooling fan problem
My main fan had a brain fart yesterday. It was working fine when i left for an hours drive. Out of no where the temp starts climbing so i pull over. The main fan stopped working!! :mad It's sunny and about 95 outside so trying to cool it down is almost hopeless. AC doesn't start fan also.
I didn't get around to much diagnostic work on the fan problem yet because i was to busy removing the leaking power steering rack !! :mad ( leak sealer turned it into a gusher) :mad
After removing rack i remembered that jumping A and B at the Aldl will make the main fan come on. It did come on ( wish i remembered this yesterday) !!
This proves the relay works so is my problem the sensor under throttlebody ?
Or since AC didn't trigger it there could be other problems.
Thanks !!! :cheers:
Also i have a sensor top right of rad (I thought this was my main fan switch)
[Modified by AGENT 86, 10:24 PM 7/21/2003]
Old Jul 22, 2003 | 09:31 AM
AGENT 86's Avatar
AGENT 86
Default Re: 86 Main cooling fan problem (AGENT 86)
TTT :eek: :D
Old Jul 22, 2003 | 09:40 AM
arbee's Avatar
arbee
In my line of work, I have found that heat can sometimes do strange things to electrical relays. It is possible that when the relay cooled down, it started working again when you jumpered A and B. I would check all of your connections and then replace the relay. They are cheap($15. our money from Chev). The sensor you refer to is the low coolant sensor.
Old Jul 22, 2003 | 09:45 AM
AGENT 86's Avatar
AGENT 86
Default Re: 86 Main cooling fan problem (arbee)
Thanks Arbee !!
Another question
Should the main fain come on as soon as i turn on AC or does pressure have to build up before fan is kicked in ?
:cheers:
Old Jul 22, 2003 | 09:52 AM
arbee's Avatar
arbee
My understanding is that the A/C kicks the fan in when pressure rises in the high line by a switch over by the evaporator box. This seems to be true as my fan cycles on and off and seems to remain on longer the hotter it is outside.
Old Jul 22, 2003 | 10:08 AM
AGENT 86's Avatar
AGENT 86
My understanding is that the A/C kicks the fan in when pressure rises in the high line by a switch over by the evaporator box..
Ahh!! I remember reading somewhere here that you could trigger the fan there.
I'll have to check it out. Thanks again !! :cheers:
Old Jul 22, 2003 | 10:15 AM
arbee's Avatar
arbee
No problem, eh!
Old Jul 22, 2003 | 07:48 PM
AGENT 86's Avatar
AGENT 86
Still looking for more insight !! :D
Old Jul 22, 2003 | 09:45 PM
jfb's Avatar
jfb
The main fan is turned on by the ECM. If the coolant sensor (under the MAF) indicates 228 F , the ECM turns on the main fan and turns it off at 211 F. If the a/c pressure switch reaches 240 psi, it opens and ungrounds pin D11 on the ECM and the ECM turns on the main fan. The a/c switch closes at 190 psi or lower amd opens at 240 psi or higher.
If the coolant temp sensor is defective, you should have a stored code 15 (low temperature) and this will not turn on the fan even though your coolant temp is above 228 F.
No error code is provided for the a/c pressure switch, but if you unplug this switch with the ign on, the fan should turn on. If it does not turn on, you have a short to ground on the green/white wire on this switch or a faulty ECM.
The a/c pressure switch is the first switch on the tubing coming out of the evaporator box on the right side, firewall.
[Modified by jfb, 8:47 PM 7/22/2003]
Old Jul 23, 2003 | 01:11 AM
AGENT 86's Avatar
AGENT 86
Default Re: 86 Main cooling fan problem (jfb)
:thumbs:
Thanks jfb !!!
Your info is always top notch !!
:cheers: :cheers:
Old May 18, 2012 | 07:55 PM
Ed Augustine's Avatar
Ed Augustine
4th Gear
Default Cooloant fan ?
Am I understanding this right. On my 86 Corvette (it came with no owners manuel). The main coolant fan, turns on only after 228 F?
That seems pretty high. I pulled over at 211 F, thinking she was going to overheat.
Old May 18, 2012 | 10:49 PM
rodj's Avatar
rodj
Originally Posted by Ed Augustine
On my 86 Corvette the main coolant fan, turns on only after 228 F?.
Perfectly normal
This thread is nearly nine YEARS old
READ
http://forums.corvetteforum.com/foru...s-or-more.html
Old May 19, 2012 | 12:24 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Holy Crap! IBTL!
Old May 19, 2012 | 07:53 AM
AGENT 86's Avatar
AGENT 86
Originally Posted by JrRifleCoach
Holy Crap! IBTL!
Wow, for a second there, I thought I woke up in the wrong year.
Old May 19, 2012 | 12:42 PM
SunCr's Avatar
SunCr
Holy Crap! The king of the Factory Service Manual actually posted this??? Oh to be young and naive again!
Old May 19, 2012 | 01:51 PM
JrRifleCoach
ME too! Like you asked a question and didn't have the diagram already posted?
Old May 20, 2012 | 03:18 AM
Cliff Harris's Avatar
Cliff Harris
Now THAT was funny. I was reading through the thread and I couldn't believe this was Agent 86 posting. It just didn't sound like the knowledgeable guy I'm used to seeing...
I guess he learned the same way I did -- plenty of problems and lots of investigation (a long and winding path) -- the infamous "school of hard knocks". ;-)
Old May 20, 2012 | 06:37 AM
HlhnEast's Avatar
HlhnEast
Yeah that blew my mind as well. I was thinking the same thing. Dan's had his car for 10+ years and he hasnt figured this out yet???
Old May 20, 2012 | 11:01 AM
AGENT 86's Avatar
AGENT 86
This is my first computer controlled car, learned a lot over the last 10 years.
To 86 Main cooling fan problem
