Dana 36 interchangable?
Old Jul 22, 2003 | 02:32 AM
linkschamp's Avatar
linkschamp
Default Dana 36 interchangable?
Can a Dana 36 pumpkin/batwing assy from an '85 bolt directly into a '92?
Coming from an automatic and going into an automatic. Would anything else have to be changed like half-shafts, driveshaft, support bar, etc.?
Thx! :seeya
Old Jul 22, 2003 | 03:19 AM
marlon88's Avatar
marlon88
Default Re: Dana 36 interchangable? (linkschamp)
Not suppose to :cheers:
Old Jul 22, 2003 | 08:56 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
If you are staying with the same ratio you shouldn't need anything else, but if the ratio is different you will want to pick up the correct set of automatic transmission speedo gears to match the new rear ratio. :steering:
Old Jul 23, 2003 | 12:21 AM
linkschamp's Avatar
linkschamp
Default Re: Dana 36 interchangable? (Ramrod92)
Yup - know about the gear change in the transmission - '85 pumpkin has a 3:07 gear set installed (GM Factory). I just wanted to be sure it was a straight swap... from the current 2:59 :)
To Dana 36 interchangable?
