Need advise
Old Jul 22, 2003 | 02:53 PM
vettehead1995's Avatar
vettehead1995
Default Need advise
I replace my transmission last week, and since I got the car back its been running like crap, I figured that it was time for tune-up. I changed the wires plugs, oil filter, air filter with no luck.
Car ideals horrible(missing)
under a load gets much worse
no oil in water or vis versa
noticed that there is a pressure leak of some sort when I shut the car off nears the plug closest to passangers seat at the back of the engine. I checked to see if the plug was loose but it was fine.
The car is not throwing any codes, what should I be looking for I figure I should check for intake leak or vacuum leak but are there any other possibilities. And would any of these coincide with the transmission??
Thanks for any help
Old Jul 22, 2003 | 02:54 PM
vettehead1995
Default Re: Need advise (vettehead1995)
Oh and I forgot, it occasionally lets out a popping noise from the exhaust
Old Jul 22, 2003 | 04:53 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Since the exhaust must be dropped to remove the tranny I'd check for a leak in that area and for a vacuum leak near the rear of the engine.
An exhaust leak in front of the O2 sensor can cause rich running and the popping.
Old Jul 22, 2003 | 05:01 PM
George Dickel's Avatar
George Dickel
Default Re: Need advise (65Z01)
It sounds like you have a vacum leak. Having only owned two GM products (79 Monte Carlo & 90 Corvette) I'm not too knowledgeable on the newer models. On the older cars there is a vacum line from the intake to the modulator on the transmission. I'm not sure if this is still used on newer models. If they still use this system, check to see if you fogot to connect it or if it has come loose.
Old Jul 22, 2003 | 05:05 PM
vettehead1995
Thanks for the replies, when you say check for a vacuum leak towards the rear of the engine, what exactly would I be looking for?
thanks
To Need advise
