Acting up...
Within a few seconds, your "Check Engine" light (early C4s) or "SYS" light (later C4s) will flash a code of 12. There will be a single flash followed by two flashes and this will repeat three times: Flash (pause) Flash Flash (long pause), Flash (pause) Flash Flash (long pause), Flash (pause) Flash Flash (long pause).
Code 12 is a delimiter or marker code to show where the error code string begins and ends.
After the three code 12 flashes, you will either get an error code (or codes) or you will get another string of code 12 flashes if there are no trouble codes stored.
All codes are repeated three times with a long pause between each code group so (for instance) you could recover a string like this: 12, 12, 12, 36, 36, 36, 44, 44, 44, 12, 12, 12.
:cheers:
