GM Top End Cleaner
Old Jul 22, 2003 | 09:31 PM
87Vert's Avatar
87Vert
Default GM Top End Cleaner
I've got an 87 with 87,000 miles. Even after a tuneup, it will knock a bit when you really get on it. When my old 84 Chevy pickup got to about the same mileage, it had a similar problem. The dealer recommended a product by GM called Top End Cleaner. You poured it down the carb and waited a while. Then after you started it, there was an awful smell/smoke, but the thing ran great! Is there a similar product I can use on the Corvette?
Old Jul 22, 2003 | 10:32 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: GM Top End Cleaner (87Vert)
You can use the same product, you just have to suck it in through a vacuum hose. :cheers:
Old Jul 23, 2003 | 01:49 AM
HighHopes85's Avatar
HighHopes85
SeaFoam is comercially available, and it is relatively the same--a top end cleaner. Dodge has their own, I believe, and as you found out, so does GM.
If the 'knocking' is pinging d/t carbon in the chambers, it is supposed to help out.
Old Jul 23, 2003 | 09:41 AM
HammerDown's Avatar
HammerDown
MotorVac.
Check out this thread
http://www.impalassforum.com/cgi-bin...&f=33&t=002148
Old Jul 23, 2003 | 10:33 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
I've been riduculed enough over this so NO FLAMES PLEASE. :rant:
PLEASE, let's don't start ANOTHER discussion on whether or not some of these 'fixes in a bottle' work or not. :cuss
YMMV but I use Marvel Mystery Oil in my fuel. It is an "upper cylinder" lubricant and cleaner.
It keeps crud off your valve stems and outta your combustion chambers including piston tops.
Old Jul 23, 2003 | 12:41 PM
Aaron's 87's Avatar
Aaron's 87
Default Re: GM Top End Cleaner (VetNutJim)
I use GM top engine cleaner a couple times a year and love it. I use a funnel and tube directly into the throttle body. Just follow the instructions on the can. Be careful, the stuff eats paint, including the garage floor, but I recommend doing it outside anyway. The more smoke you get, the better the car will run after the smoke burns off.
Old Jul 23, 2003 | 05:03 PM
ZylaRace's Avatar
ZylaRace
Default Re: GM Top End Cleaner (Aaron's 87)
Water will have the same effect. Ever see a cyl head that had a gasket failure?
Steam cleaned cyl's.
I have alway's thought "Top Engine Cleaner" was just Sea Foam in a GM can.
Old Jul 23, 2003 | 05:30 PM
BBA's Avatar
BBA
Default Re: GM Top End Cleaner (ZylaRace)
Yea...just take aa mixture of water and antifreeze and suck it in through a vacuum hose on the throttle body. Run about two gallons through and it will be as clean as new. (Well...close to it anyway).
Old Jul 23, 2003 | 05:32 PM
scorp508's Avatar
scorp508
Be careful and follow the directions. We had a guy hydrolock his engine not too long ago using this stuff.
Old Jul 23, 2003 | 06:38 PM
BBA's Avatar
BBA
Default Re: GM Top End Cleaner (BBA)
In fact...I just got the urge and ran two gallons of water/antifreeze mix through mine.
The neighbors didnt even notice much since it is raining outside. :)
I guess we'll see if the pinging goes away on the next hot dry day that comes along.
Old Jul 23, 2003 | 06:46 PM
HighHopes85
It gives me just enough time to buy stock in Bosch so I can take advantage of their increased O2 sensor sales... :confused:
Old Jul 23, 2003 | 06:51 PM
BBA's Avatar
BBA
Default Re: GM Top End Cleaner (HighHopes85)
LOL...I didnt run that much antifreeze in it.
Besides, O2 sensors live through a LOT of ****. Mine is only about a year old so I think it will survive this once or twice. :D
To GM Top End Cleaner
