car bogs when cold
Old Jul 22, 2003 | 10:24 PM
CarAteMyMoney's Avatar
CarAteMyMoney
Default car bogs when cold
ive noticed if i hit the gas in neutral before my car is all warmed up the throttle response really sucks and the car kinda bogs
any ideas? its got new plugs, accel wires, accel cap, rotor, o2, timing is right on, msd box,
Old Jul 22, 2003 | 10:49 PM
vmi_vette's Avatar
vmi_vette
Default Re: car bogs when cold (CarAteMyMoney)
Check you coolant sensor. If the car thinks it is operating at the wrong temp, it could be sending the wrong amount of full. Just an idea.
Old Jul 23, 2003 | 07:18 PM
CarAteMyMoney
Default Re: car bogs when cold (vmi_vette)
i justput in those accel custom fit wires, can that have anything to do with it?
Old Jul 24, 2003 | 10:06 AM
HammerDown's Avatar
HammerDown
Mine has started doing this too.
:lurk:
Old Jul 24, 2003 | 05:05 PM
CarAteMyMoney
Default Re: car bogs when cold (HammerDown)
is it fine when it warms up?
Old Jul 24, 2003 | 05:13 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
My thoughts are that any car....be it vette or whatever would "BOG"..when cold...at least until it reached normal operating temp's......
Don't you???????????????????????????
We have all been around to know that fact.......haven't we??????????
tony :crazy:
:eek: :eek: :eek:
Old Jul 24, 2003 | 08:21 PM
vmi_vette's Avatar
vmi_vette
FYI...
Before I got the custom chip for the LT4 Hot cam I had installed, my car would not respond smoothly to throttle inputs when cold/slightly warmed up. It felt like the car was bogging down. Basically the stock programming was commanding the wrong fuel flow. It was fine during cruising and steady state throttle position because the car was in closed loop. With the new chip, the car will take off even if cold.
Keep in mind that you shouldn't rev the engine very high until it reaches operating temperatures.
:seeya
Old Jul 24, 2003 | 08:37 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
1. Check for a vacuum leak. That will cause it to be real lean when cold.
2. Check your cold start injector (if you have one) drivers cide lower manifold area. Make sure its plugged in and working.
3. Make sure you have the proper basic state of tune i.e. good wires, plugs, air filter ect.
Good luck and keep us informed on how you make out.
Bill C
To car bogs when cold
