A/C Problems, any suggestions?
Old Jul 24, 2003 | 08:17 AM
GS348's Avatar
GS348
Default A/C Problems, any suggestions?
My 96 GS's a/c is acting up. The compressor kicks on, but all of the vents on the dash are not working. The lower vents underneath the dash and the defrost vents are functioning. I've checked the fuses and they are alright. My mechanic is backed up and is not taking any appointments for at least a week, but he suspects the a/c programmer underneath the dash to be bad which is about $600--OUCH! Has anyone had a problem similar to this and if so a cure?
Old Jul 24, 2003 | 10:53 AM
dlmeyers's Avatar
dlmeyers
Default Re: A/C Problems, any suggestions? (GS348)
When I see this type problem, most suggest checking the vacuum connections on the engine. If you have a service manual, check out the schematics and for the vacuum signal that opens the vent. I would not spend big money on a new controller until I knew the control was getting vacuum from the engine.
Good luck and let us know
dlmeyers 90 coupe zf6 3 speed shocks
Old Jul 24, 2003 | 11:33 AM
nitrous1's Avatar
nitrous1
St. Jude Donor '06-'07-'08-'09
This has all the symptons of a vacuum leak. Check under the hood for a loose or broken vacuum line. Then check under the dash to make sure everything is hooked up there.
Dan
Old Jul 24, 2003 | 11:50 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Chris,
Have a look under your passenger fuel rail cover. There is a black plastic vacuum check valve there that tends to deteriorate over time. They're cheap. It supplies vacuum to the A/C I believe. Is your Cruise woirking?
Old Jul 24, 2003 | 01:54 PM
GS348's Avatar
GS348
Default Re: A/C Problems, any suggestions? (dlmeyers)
Hey thanks for the information, I'll check it out. :yesnod:
Old Jul 24, 2003 | 01:56 PM
GS348's Avatar
GS348
Default Re: A/C Problems, any suggestions? (nitrous1)
Thanks, I hope that's the issue
Old Jul 24, 2003 | 05:05 PM
SouthernSon's Avatar
SouthernSon
It is more than likely the programmer. I followed the advise in this link and bought a rebuilt one from the 'last detail' for less than $200 and installed it myself. You can replace it in less than an hour for the first try. Check out this site and let me know if you need more instructions. http://www.hashmarks.com/techtips/ac_problems.htm
Old Jul 24, 2003 | 05:31 PM
NE14SIN's Avatar
NE14SIN
I don't mean to sound like an azz when I say this, but are you sure that it just isn't doing what it is suppose to do? When I hit Auto on my A/C, it turns on the lower vents and the dash vents for a few minutes before it turns on the ones that aim right at the passangers. I just turn down the A/C fan speed to 8, and it kicks right on.
Old Jul 28, 2003 | 11:22 PM
GS348's Avatar
GS348
Default Re: A/C Problems, any suggestions? (NE14SIN)
I'm sure, thanks.
Old Jul 31, 2003 | 02:09 PM
Jim P.'s Avatar
Jim P.
RAY Quayle said it...check under the passenger fuel rail cover first. There's a black plastic vacuum switch under there. The AC in my 96 was acting up and it turned out to be that 5 dollar part.
Check the cheap and simple stuff first or you may get HOSED by one of these repair shops. Some shops will stick it to you even if they do find a cheap part.
THere's so many dishonest shops!
:yesnod: :cool:
To A/C Problems, any suggestions?
