Wheel problem
Old Aug 1, 2003 | 08:08 AM
Bradley33's Avatar
Bradley33
Default Wheel problem
Something is wrong with my right front tire. It feels kind of "wobbly" sort of like the tire is halfway off.
The tire is on just fine.
The problem is almost non-existent on smooth payment, but when the road gets a little rough it's pretty bad. The steering wheel does not jump around at all, it stays smooth, and if I let go of the wheel the car stays straight. I can feel a slight vibration in the accelerator. As far as I can tell, the shocks are fine.
I'm getting this looked at tomorrow, but I have NO idea what this could be. Anyone have any ideas as to what might be causeing this?
Old Aug 1, 2003 | 08:39 AM
bogus's Avatar
bogus
Default Re: Wheel problem (Bradley33)
hm. bad wheel bearing?
Old Aug 1, 2003 | 09:13 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Wheel bearing
Tie rod end
Ball joint
:smash: :cheers:
Old Aug 1, 2003 | 10:05 AM
CMYC4GO's Avatar
CMYC4GO
Did you check to see if you lost a balance weight?
Old Aug 1, 2003 | 02:27 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
When was the last time you had your wheel/wheels balanced ?
Maybe?
I hope its that easy.
Well good luck.
tony
:chevy :chevy :chevy
Old Aug 2, 2003 | 12:09 PM
Bradley33's Avatar
Bradley33
Default Re: Wheel problem (oldace84)
Turns out I have two bad ball joints.
My shocks are pretty bad too.
Corvettes sure are expensive!! :yesnod:
To Wheel problem
