Catalytic Converters
Old Aug 3, 2003 | 10:17 AM
POLOVETTE 94's Avatar
POLOVETTE 94
Co-winner 2020 C4 of the Year - Modified
Default Catalytic Converters
I am in Maryland, where we have emissions testing, so I need to keep converters on the car. My whole exhaust is off right now, and I was wondering if it is worth buying the Random Tech high flow cats, or should I just put the stock (70,000 miles on them) converters back on? I already know from other forum members that full length headers with a y-pipe and single converter is not going to work out on an automatic LT1 car, so I will probably go with the Hooker shorties, converters, and a good cat back system. Has anyone had any good results from the Random Tech converters, or should I save the money and put the old ones back on? I'm sure new GM ones probably cost more than the Random Tech ones anyway.
Old Aug 3, 2003 | 02:11 PM
93 ragtop's Avatar
93 ragtop
Default Re: Catalytic Converters (POLOVETTE 94)
IMHO as long as your stock cats are not stopped up, then you will be wasting money replacing them. By the way, TPIS shows a LT header system that uses 1 cat for the LT1 cars (92-96) I believe it is basicially their headers with a L98 style exhaust system.
Old Aug 3, 2003 | 02:44 PM
Rays91L98's Avatar
Rays91L98
I live in Md also, I recently installed headers (HOK-2149) and replaced the front two precats with a 3" Y-pipe that I bought with the headers, I left the main Cat for emissions. IMHO adding the headers and removing the pre cats made a huge differnece in the SOTP feelng taking off from the line. Also my AVG gas mileage before 16mpg, after 21.4 mpg, so I believe the pre cats were at least partially clogged, by the way the car has 76 k miles. I haven't retested emissions since but from what I've read it shouldn't be an issue with the main cat and smog equipment still on the car. my 2 cents.
:seeya
[Modified by Rays91L98, 5:55 PM 8/3/2003]
Old Aug 4, 2003 | 09:17 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
My Random Tech Cat works very well, Happy with the change in sound also.
Good Luck
tony
:chevy :chevy :chevy
[Modified by oldace84, 6:18 AM 8/4/2003]
Old Aug 4, 2003 | 12:29 PM
96GS#007's Avatar
96GS#007
Default Re: Catalytic Converters (93 ragtop)
:iagree: LT1/4/5 cats are completely different than the L98. You're just wasting money by swapping them out.
To Catalytic Converters
