wanted knowledge!!!!!!!
Old Aug 6, 2003 | 08:37 AM
ladystoy69's Avatar
ladystoy69
Default 85 tpi. mass sensor & t.b parts and or knowledge wanted
wented 85 or equivelant mass air flow sensor and throttle body and ori need anyone with extensive knowledge of 85 corvette 350 tpi.... as i am in need of interchange information for the mass air flow and throttle body assemblies interchangability amonge vettes and camaros... imfo needed asap so if you have this knowledge please respond to my email with your phone number so i can call you.... would greatly appretiate this help thanks....
xtream692003@msn.com
[Modified by ladystoy69, 7:38 PM 8/6/2003]
Old Aug 6, 2003 | 02:42 PM
ladystoy69's Avatar
ladystoy69
Default Re: 85 tpi. mass sensor & t.b parts and or knowledge wanted (ladystoy69)
please help needed asap as i am 700 mi. from home
:confused:
Old Aug 6, 2003 | 10:41 PM
ladystoy69's Avatar
ladystoy69
up
:nonod:
Old Aug 6, 2003 | 10:52 PM
BBA's Avatar
BBA
Cant you just go buy one or do you have one from another car already?
Old Aug 6, 2003 | 10:59 PM
ladystoy69's Avatar
ladystoy69
Default Re: 85 tpi. mass sensor & t.b parts and or knowledge wanted (BBA)
found two but get verying replys as to wheather the parts will be a direct fit even the chevy dealers cant seem to agree lot of money for a chance :confused:
Old Aug 6, 2003 | 11:32 PM
Heckler45's Avatar
Heckler45
this might sound strange but you can try calling some of the bigger crvette parts places like eckler's midamerica or caorvette central as they have technitions on hand to answer questions. Hope this helps.
:cheers:
Old Aug 6, 2003 | 11:38 PM
vader86's Avatar
vader86
I believe the MAF's will interchange loosely, the MAF on corvettes is actually 3 different models:85, 86-87, 88-89 but you can interchange and get by without a trouble code if youre lucky. Ive never looked up the P/N to be sure on what changes between Fbodys and Corvettes.
You could call up Autozone and ask about the P/N to check.
As far as actually bolting up the TPI to the block and TB to the TPI, that should be the same.
To wanted knowledge!!!!!!!
