86-89 console switches
Old Aug 13, 2003 | 12:50 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default 86-89 console switches
I ordered a carbon fiber dash for my 86 and the console covers didn't fit mine so i shipped it back and they are going to rectify the problem. The console covers they shipped me both had 4 switch holes. What is the fourth switch hole for ?
Thanks :cheers:
Old Aug 13, 2003 | 08:53 AM
AGENT 86's Avatar
AGENT 86
Default Re: 86-89 console switches (AGENT 86)
Nobody have a fourth switch ?
Old Aug 13, 2003 | 06:06 PM
AGENT 86's Avatar
AGENT 86
TTT for the one man show !! :crazy:
Old Aug 13, 2003 | 07:52 PM
JCAIRE2's Avatar
JCAIRE2
I'm having a hard time picturing what you're describing. What switches on the console, the window switches?
Old Aug 13, 2003 | 07:59 PM
CREWZIN's Avatar
CREWZIN
86,
If I take your posting right, you mean the 4 switches in the center console on the left side under the 4 vent squares. The 4 switches that I have on my 87 are: oil press/oil temp, coolant temp/volts, range/trip ODO, instant fuel range/average fuel range. Is that the 4 your talking about??
[Modified by CREWZIN, 8:01 PM 8/13/2003]
Old Aug 14, 2003 | 01:28 AM
AGENT 86's Avatar
AGENT 86
Default Re: 86-89 console switches (JCAIRE2)
Yes,there are 2 window switches,and 1 for control of left/right mirror. The shifter console cover they sent me had a fourth switch hole.This pic should ease the confusion :D
:cheers:
Old Aug 14, 2003 | 01:31 AM
JCAIRE2's Avatar
JCAIRE2
Aha! I have No idea what the 4th hole is for :crazy:
Old Aug 14, 2003 | 04:39 AM
SharkB4C4's Avatar
SharkB4C4
The the 4th hole is for the OD switch on 84-85 cars with the 4+3 transmission. The OD switch was moved to the shift **** in 86.
[Modified by SharkInShark, 1:40 AM 8/14/2003]
Old Aug 14, 2003 | 08:56 AM
HeeHaw89's Avatar
HeeHaw89
Default Re: 86-89 console switches (SharkInShark)
What about the adj suspension switch? Was that on the console in 89?
Old Aug 14, 2003 | 08:57 AM
HeeHaw89's Avatar
HeeHaw89
Default Re: 86-89 console switches (HeeHaw89)
Also, looking at the above picture, what was the hole above the shifter? I thought that was where the o/d switch was.
Old Aug 14, 2003 | 08:59 AM
HeeHaw89's Avatar
HeeHaw89
Thanks :cheers:
Just wondering, where are you getting the carbon fiber dash?
Old Aug 14, 2003 | 09:56 AM
AGENT 86's Avatar
AGENT 86
[quote]The the 4th hole is for the OD switch on 84-85 cars with the 4+3 transmission. The OD switch was moved to the shift **** in 86.[quote]
This seems like a good answer,i thought that it was on the center dash.
[quote]Also, looking at the above picture, what was the hole above the shifter? I thought that was where the o/d switch was.[quote]
That hole is for the 4+3 emblem.
[quote]What about the adj suspension switch? Was that on the console in 89?[quote]
I was thinking the same but not sure about it.
[quote]Just wondering, where are you getting the carbon fiber dash?[quote]
I got it here.http://www.autoaccessorystore.com
Still confused :confused:
:cheers:
[Modified by AGENT 86, 6:57 AM 8/14/2003]
[Modified by AGENT 86, 6:58 AM 8/14/2003]
Old Aug 14, 2003 | 06:26 PM
Wheelman's Avatar
Wheelman
Some 89s had this option....placement of the switch was on the console between the window switches. It would be a square hole....
Old Aug 14, 2003 | 09:11 PM
AGENT 86's Avatar
AGENT 86
Default Re: 86-89 console switches (Wheelman)
You mean like this pic
I got every shift plate but mine :smash: :smash: :smash: :smash: :smash:
To 86-89 console switches
