Oil question
Old Aug 13, 2003 | 03:32 PM
black_89_vette's Avatar
black_89_vette
Default Oil question
Ok, in this thread there will be a lot of people telling me to go to Mobil 1.
But this thread is a different question.
What is the advantage of Valvoline VR1 Racing Formula 20w50
vs.
Valvoline 20w50.
Basically, what is the VR1 Racing Formula's difference?
Old Aug 13, 2003 | 03:36 PM
J Z06's Avatar
J Z06
Maybe the racing formula is intended for higher rpm engines that see higher operating temperatures?
Old Aug 13, 2003 | 03:39 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
Default Re: Oil question (Jay 383)
Try going to:
http://www.bobistheoilguy.com
Matt
Old Aug 13, 2003 | 03:49 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Default Re: Oil question (black_89_vette)
Never used it. :confused:
Old Aug 13, 2003 | 05:50 PM
Southern Comfort's Avatar
Southern Comfort
Default Re: Oil question (MJT383NO2)
Well Bob the Oil Guy is quite a fellow. :crazy:
Old Aug 14, 2003 | 09:02 AM
mountainmotor's Avatar
mountainmotor
In the past it had alot more Zinc and Phosporous along with added anti foam and different or less viscosity index improvers . It has been reformulated and uses more Anti-Wear additives" not zinc " and Emulsification additives for use with fuels such as Methanol .
It is still available and they have dropped the straight 40 wt from the lineup but now offer a real racing only 5/30 wt that should not be used on the street for long term . This racing only 5/30 and the Redline racing only oil are the only two available oils I personally know of that actually should be used for racing only and not on the street as far as the old wives tail of racing oils cannot be used on the street is concerned.
[Modified by mountainmotor, 8:14 AM 8/14/2003]
To Oil question
