Relay draining battery
Old Aug 14, 2003 | 09:27 AM
19Fuzzy85's Avatar
19Fuzzy85
Default Relay draining battery
I own a stock 1985 vette which developed this problem overnight. There seems to be a relay or switch which opens and closes even when the car is off and then drains the battery. The sound is loud and actually dims the courtesy lights. Sounds like it is coming from the rear of the car but I have yet to pinpoint the location. Anyone else experience this problem? Thanks
Old Aug 14, 2003 | 10:05 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Relay draining battery (19Fuzzy85)
Possible power antenna relay located under trim beside hatch latch.
Old Aug 14, 2003 | 10:11 AM
MtlSphere's Avatar
MtlSphere
Is your antenna moving?
Kinda sounds like the ribbon in the antenna is broken and the motor is still trying to bring it down...
Pull the fuse for the radio and see if the noise stops...
Welcome to the forum... :seeya
Old Aug 14, 2003 | 10:15 AM
19Fuzzy85's Avatar
19Fuzzy85
Default Re: Relay draining battery (AGENT 86)
Thanks, I know the exact relay you referring. Thanks again for your insight. :cheers:
Old Aug 14, 2003 | 10:16 AM
19Fuzzy85's Avatar
19Fuzzy85
Default Re: Relay draining battery (MtlSphere)
I really appreciate your time, I'll also check the antenna and pull the fuse. Thanks Again, :cheers:
Old Aug 14, 2003 | 12:12 PM
RM 4 TWO's Avatar
RM 4 TWO
I have a similar problem with my 92's fuel pump. It stays on after turning the car off. It's drained the battery twice now and I still don't know why it's doing that. Doesn't happen all the time, mostly after I wash the car but not always. I think I may be getting a relay wet or something? But like I said, it doesn't happen all the time.
Old Aug 14, 2003 | 03:08 PM
19Fuzzy85's Avatar
19Fuzzy85
Default Re: Relay draining battery (RM 4 TWO)
Thanks for your reply. After hearing what you're going through, I just hope mine is theantenna or antenna relay. Good luck in fixing yours. :cheers:
To Relay draining battery
