Engine stops for no apparent reason?
Old Aug 15, 2003 | 09:42 AM
85 Habu's Avatar
85 Habu
Cruising
Default Engine stops for no apparent reason?
Hi Everyone! My 85 Corvette runs great 99 % of the time. However sometimes it will just shut off with no warning. Leaving a stop light or just ideling, I just pull over crank the engine usually on the second try starts up runs great? I have installed a new fuel pump, both fuel filters, new cap, rotor and plug wires. New plugs.......Trouble shooting guides not addressing this problem? Advice is welcome!
Old Aug 15, 2003 | 09:47 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Engine stops for no apparent reason? (85 Habu)
Possible IAC problem if it is associated with idle. Have you cleaned the TB and IAC lately ??
:cheers:
OH !! Welcome to the forum :seeya
Read these links,they may help you.
https://www.corvetteforum.com/techti...=195&TopicID=2 https://www.corvetteforum.com/techti...D=55&TopicID=2
[Modified by AGENT 86, 6:54 AM 8/15/2003]
[Modified by AGENT 86, 7:00 AM 8/15/2003]
Old Aug 15, 2003 | 10:16 AM
loflyin's Avatar
loflyin
Default Re: Engine stops for no apparent reason? (AGENT 86)
Consider the four way connector and its associated wires from the distributor. If the ECM doesn't receive the reference signal from the distributor, it will immediately stop pulsing the injectors. If this is an intermittent problem, it will be a bear to check out. If the EGR were at fault, it would most likely shut off when decelerating, more so than at idle. Hope this is a little help.
Old Aug 15, 2003 | 11:08 AM
vetracer's Avatar
vetracer
Default Re: Engine stops for no apparent reason? (loflyin)
I had a similar problem which turned out to be the wires at the MAF power relay connector shorting out. I have seen other members post pictures of the same thing; the insulation covering the wires near the connector somehow shrinks back, leaving bare wires exposed. It's worth a look...
BTW these relays are located behind the battery.
Old Aug 15, 2003 | 11:45 AM
LD85's Avatar
LD85
Default Re: Engine stops for no apparent reason? (vetracer)
Mine did that when I first got it, I replaced the HEI module and it never happend again.
Old Aug 15, 2003 | 02:55 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Engine stops for no apparent reason? (ld85)
All the above would be things to check.
BTW Welcome to the forum. Interesting user name. Been in SE Asia? Seems very few people know what a habu is.
Old Aug 15, 2003 | 10:39 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Just a few thoughts. The fuel pump? And or the fuel filter?
Have you checked fuel pressure at the injectors?
Just a thought.
Good Luck
tony
:chevy
To Engine stops for no apparent reason?
