Need help!
Old Aug 21, 2003 | 09:48 PM
91superram's Avatar
91superram
Default Need help!
Car will only run with Knock sensor disconnected and TPS set to .44Volts
Can someone tell me why this is happening and when its connected, it back fires and runs rich. If I set the TPS to .54Volts its even worse
Old Aug 21, 2003 | 10:17 PM
neverendingproject's Avatar
neverendingproject
Default Re: Need help! (91superram)
has anything been done that could have led to this problem? 91 is an l98 right? just digging for more info
Old Aug 21, 2003 | 10:19 PM
scorp508's Avatar
scorp508
Default Re: Need help! (neverendingproject)
What does your O2 millivolt readings say when it runs good and then when it runs badly?
Old Aug 22, 2003 | 09:43 AM
91superram's Avatar
91superram
Default Re: Need help! (scorp508)
This has been a problem since I installed my modified motor.I also tried changing my 02 sensor to a heated one but still didnt work so I took it to the local performance shop and noticed they disconnected my knock sensor completly.Car seems to run fine but want to know why?
Old Aug 22, 2003 | 09:49 AM
91superram's Avatar
91superram
Could it be my valves not set properly?
Old Aug 22, 2003 | 11:18 AM
BIG JIM 54's Avatar
BIG JIM 54
Have you checked the timing?
BIG JIM
Old Aug 22, 2003 | 12:43 PM
tjwong's Avatar
tjwong
Default Re: Need help! (BIG JIM 54)
What year is your car? Have you checked for any diagnostic codes?
Old Aug 23, 2003 | 08:46 PM
91superram's Avatar
91superram
Found the problem. Traced it back to a broken wire at the Knock sensor
To Need help!
