91 vette gears
Old Aug 21, 2003 | 11:20 PM
6spd's Avatar
6spd
Default 91 vette gears
will 4.10's be much better than the stock 3.45's is the swap worth it???????
Old Aug 22, 2003 | 01:26 AM
TA's Avatar
TA
Default Re: 91 vette gears (6spd)
On an L98 I'd say 4.10s would be WAY to steep unless you have extensive mods. I switched from 2.59s to 3.07s and have yet to see a gain :yesnod:
Old Aug 22, 2003 | 12:27 PM
vader86's Avatar
vader86
NO, not unless you have a Miniram on top of it.
Youd be out of your powerband very quickly.
Old Aug 22, 2003 | 12:30 PM
scorp508's Avatar
scorp508
I'd leave it as is until you start making mods to take advantage of 6000 RPM or so. :)
Old Aug 23, 2003 | 12:50 AM
vetracer's Avatar
vetracer
The 3:45's are a pretty good gear for the L98, that's what I have after changing to 3:73's which I did not like. Spend the $$ on other mods, like Scorp and Vader said you need a pretty high revving motor to use gears that low. Besides, IMO it gets pretty old doing normal driving around town with gears that low, you are either constantly shifting or skipping gears.
[Modified by vetracer, 10:51 PM 8/22/2003]
To 91 vette gears
