crank case pressure
Old Aug 27, 2003 | 01:52 PM
lead foot 85 vet's Avatar
lead foot 85 vet
Default Re: crank case pressure (krivera)
Ronnie--w what your doing should work ...whats the problem? still to much crankcase pressure?
Old Aug 27, 2003 | 01:55 PM
black bart's Avatar
black bart
Default Re: crank case pressure (Ronnie_W)
Thanks Bart, I have the evac kit but am only running one oil separater from the valve cover to the exhaust at this time and one oil separater from the other valve cover to the supercharger intake. I guess I will drill one of the valve covers for a breather and take the line going to the intake and tie it into the exhaust instead.
I would not run a hose from the valve cover to the blower intake. Some on the froum do this and it has been argued about how good of an idea it is. If you ever drove any lenght of time with a hose like that then remove it and look at the inside it will be wet. The fumes contain oil and it will coat the inside of the blower and intercooler. Once it is oil coated it is no longer efficient at cooling the air.One other benefit of the evac system is it will allow the engine to make more power by removing pressure from the rings they then seal better and the engine makes more power as a result. Every little bit helps I have a windage tray and a crank scrapper maybe you think a little thing like that don't help much but a good friend of mine wrenchs on a sprint car they put it on an engine dyno and run it with a standard oil pan and then ran it with a pan like I use and gained 43 hp. Attention to the small details adds up to make the difference at the finnish line.
Old Aug 27, 2003 | 02:36 PM
vvv90's Avatar
vvv90
Default Re: crank case pressure (black bart)
THAT'S IT! I'm sold. :yesnod:
I was looking at the Moroso kit but it has two breathers. I'm not sure how the L98 is setup but the LT-1 only has a hole in the passenger valve cover and a hole in the drivers side manifold where the old PCV valve was.
What do you guys suggest it do with that side?
:confused: :confused: :confused:
Old Aug 27, 2003 | 03:09 PM
Ronnie_W's Avatar
Ronnie_W
Default Re: crank case pressure (lead foot 85 vet)
I think it still has a little too much pressure. I can see where oil is being pushed out the valve cover bolt holes. The engine probably don't have a 100 miles on it yet, maybe 30 with the blower. Still trying to work out other issues also. I wanted to have the crankcase pressure under control by the time I start running this thing. I will try and copy what Black Bart is doing and see if it works for me. I just have to drill another 1 1/2" hole for a breather.
Old Aug 27, 2003 | 03:17 PM
Ronnie_W's Avatar
Ronnie_W
I was worried about the oil going into the intake so I put an oil/air separator in line between the valve cover and the intake. The separator is the type you would put in line on your compressed air system. The separator maybe too much of a restriction. Anyway, I will be moving the line going to the blower intake to the exhaust evac line.
[Modified by Ronnie_W, 3:45 PM 8/27/2003]
Old Aug 27, 2003 | 03:48 PM
black bart's Avatar
black bart
Default Re: crank case pressure (vvv90)
If you look at the picture of my engine right side you will see the oil fill cap is gone in it's place is a oil seperator when I put oil in it I remove the breather at the rear of the RH valve cover. If you drill a hole you can buy baffles to install or do like me I made mine. When engine is at low rpm the one way valve in the evac system will close so you will need a breather High rpm may force a very small amount of oil through the seperator but the flash point on oil is around 450 to 470 depends on the oil but when it hits the 1000 degrees in the collector it will burn instantly you may see a slight puff of smoke out the pipes.
Old Aug 27, 2003 | 05:19 PM
vvv90's Avatar
vvv90
So is it necessary to have both a traditional Filter/breather (like in the rear of your valve cover) and an evac also?
In other words, do you need both a traditional breather and moroso evac breather?
Or, can I just run the moroso breathers into my exhaust, essentially venting ALL crank case gases to the exhaust?
(clear as mud :rolleyes:)
[Modified by vvv90, 4:19 PM 8/27/2003]
Old Aug 27, 2003 | 06:23 PM
black bart's Avatar
black bart
YES
Old Aug 27, 2003 | 08:57 PM
vvv90's Avatar
vvv90
o.k. I'm trying to figure this out....is it because at idle there won't be enough
exhaust flow/vacuum to pull out the gases and they need to come out the valve cover filter, but at WOT the velocity flow of the exhaust will take over and actually pull the gases out of the crankcase preventing the oil from saturating the filter otherwise?
In any case, I'm going to have to convert my oil fill cap to a breather.
O.k. so let me kow if I have this right....I put a filter on the rear hole on the
passenger side, convert my oil fill cap to the moroso style breather....but
what do I do with the hole in my instake manifold on the dirver's side? Is it
safe to just cap it? THeoretically shouldn't the left and right bank have just as much pressure as the intake manifold from the crankcase?
What about just T-ing the intake manifold opening to the evac tube?
Sorry for all the questions. :leaving:
[Modified by vvv90, 8:00 PM 8/27/2003]
Old Aug 27, 2003 | 09:22 PM
black bart's Avatar
black bart
CORRECT
Plug all openings on the intake their should be no connection between the intake and the crankcase.
If you have a state inspection then they will require it otherwise plug everthing. The moroso is not a breather it is a oil seperator the one way valve has a spring in it to prvent hot exhaust gas from coming up the hose the pipe that you weld in is cut at a 45 degree angle as the high velocity exhaust passes it will make a vacuum on it and open the valve also when crankcase pressure increases it will push on the valve. With the breather if pressure becomes more than what can go out the hose it will flow out the breather at low speed the breather will do all the venting. NOW IS IT CLEAR AS MUD
Old Aug 28, 2003 | 10:43 AM
vvv90's Avatar
vvv90
:thumbs: :thumbs:
Thanks Bart man, I just feel more comfortable understanding the physics behind it is all. I don't want any surprises when I'm done modding and hacking.
:cheers:
One last question. The Moroso kit comes with two separators. Is it absolutely important to have one on each valve cover? Or am I safe just doing one side? :leaving:
Old Aug 28, 2003 | 11:03 AM
krivera's Avatar
krivera
I have heard to run both if i am correct...bart said that before along time ago? or i heard it some where?
Old Aug 28, 2003 | 02:27 PM
  #33
black bart's Avatar
black bart
:thumbs: :thumbs:
:cheers:
With two you will still be pushing some out the breather under heavy boost. Only thing better than two would be three.
You could go with a vacuum pump but then you have to find a place to mount it and build pulleys lot easier with what I used. Don't make any holes until you have the breathers. They are a lot of different kinds. I have one the I think it is 1 1/2 inch opening and it clamped on so I got a piece of nylon cut it to length then turned it in my lathe to fit the breather. I left enough stick out to nearly reach the head turned it to fit the rubber grommet real tight then bored a hole in the center leave about 3//16 wall then I drilled a lot of small holes in the side pluged the bottom with rtv then put stainless steal core ball material in the center hole put it in the breather and clamp it then just push it into the grommet on the valve cover. Shop around see what you can find for a breather and use both of the oil seperators. I worked on my car today it was wanting to die if I pushed the clutch in at high rpm. I read the manual again and applied my new found wisdom to the dfi and Waala she just drops down to idle with no undershoot and idles perfectly. :) :hurray:
Old Aug 28, 2003 | 02:32 PM
  #34
black bart's Avatar
black bart
MATT My bill for all of this is in the mail. :lolg: :lolg:
Old Aug 28, 2003 | 02:45 PM
  #35
vvv90's Avatar
vvv90
Just don't charge me $85 a hour like the General and I'll pay it! :rofl:
Old Aug 28, 2003 | 02:55 PM
  #36
vvv90's Avatar
vvv90
O.k. I think I'm going to order the Mr. Gasket kit because it's looks to be the same except for chrome separators instead of Iodized ones. (looks preference :D )
Also, Spectre makes a screw in breather for the oil cap: Summit part# SPE-4281
Before I order I just want to make sure that this will still work without having headers.
Am I going to be creating too much back pressure with my stock exhaust manifolds for this to work properly?????
Old Aug 28, 2003 | 04:19 PM
  #37
black bart's Avatar
black bart
I don't know what you have after the stock manifolds ??? pre-cats and main cat but if you have all that it should work OK install in the exhaust pipe after the pre-cats. I would try to put them where when you get headers they will fit without changing the hose. Two things to asK Summit when you call is does the screw in breather have a baffle on it if not you will have to make one and is the Mr. gasket evac kit just a breather type or is it a oil seperator. The Moroso is a oil seperator and it cost a lot more so you got to wonder if the gasket is not just a cap with a hose connection on it. I had my Moroso chrome plated. If you get something other than an oil seperator you will blow oil into the exhaust real bad. Maybe you could hire out to the city as a mosqiuto killer :lolg: We will call you OLE-SMOKEY :lol: :lol: :lol:
[Modified by black bart, 4:21 PM 8/28/2003]
To crank case pressure
Old Aug 28, 2003 | 05:20 PM
  #38
vvv90's Avatar
vvv90
No pre-cats, just cats.
Good points you make, yes. Make a call to Summit, I will.
Old Aug 28, 2003 | 06:04 PM
  #39
krivera's Avatar
krivera
vvv90---> :steering: SMOKE---> :U Black Bart--> :lolg: Corvette forum members :nono: :sad: :thumbs: :rofl: :leaving: :lolg: :lol: :eek: :eek: :rolleyes: :_dupe: and vvv90 mad as heck---> :cuss so the corvette forum member all run---> :leaving: :yawn: :rofl: :leaving:
Old Aug 28, 2003 | 08:50 PM
  #40
vvv90's Avatar
vvv90
Kev what the hell are you smokin' ????
:lol:
