crank case pressure
Old Aug 22, 2003 | 04:14 PM
Ronnie_W's Avatar
Ronnie_W
Default crank case pressure
What are you supercharged guys using to relieve crank pressure? I have one valve cover connected to the exhaust via evac kit and the other valve cover connected to the intake of the supercharger via the other breather/filler cap that came with the exhaust evac kit and then through an air-oil separator. This don't seem to be working too good. Would I be better off to just put a regular breather in each valve cover? :confused:
Old Aug 22, 2003 | 05:33 PM
krivera's Avatar
krivera
Default Re: crank case pressure (Ronnie_W)
[QUOTE]Would I be better off to just put a regular breather in each valve cover? /QUOTE]
yes...let me dig up some pics really quick..
but i have to baby K&N's right now and then when emissions comes i run tubes to the air filter :nono:
Old Aug 22, 2003 | 05:40 PM
Ronnie_W's Avatar
Ronnie_W
Default Re: crank case pressure (krivera)
I have a couple of the baby air filters laying around. I will try them.
Old Aug 24, 2003 | 08:45 PM
lead foot 85 vet's Avatar
lead foot 85 vet
vent every hole in the valve covers including the oil fill and then run a hose from the vent filters or the filters will become pluged with oil and then drip on your valve covers....at least thats what I did but you can eat off my engine. :chevy
Old Aug 25, 2003 | 11:53 AM
vvv90's Avatar
vvv90
Default Re: crank case pressure (lead foot 85 vet)
and then run a hose from the vent filters ....
:confused: run the hose to where?
Currently I did what ATI said :rolleyes: and ran the hose to the air filter. This is SUCH a bad idea. I want a better solution....
Hey Black Bart!!!! How's yours again???
Old Aug 25, 2003 | 02:10 PM
lead foot 85 vet
Default Re: crank case pressure (vvv90)
The engine in my 85 is very tired it has 120,000 miles and the supercharger is killing it ( about 12,000 spercharged miles) I have blowby and I just run hoses to the bottom of the engine bay to remove the oil mist from settling on the valve covers............I tried the filters but after a summer they would drip on the valve covers and that was unexceptable............new motor under construction......by the way spector makes filters with a hose attachment. :chevy
Old Aug 25, 2003 | 03:22 PM
vvv90's Avatar
vvv90
Oh, I gotcha :thumbs:
Old Aug 25, 2003 | 05:14 PM
black bart's Avatar
black bart
Matt when you get ready to install the new engine IM me and I will tell you how to cure this problem. :yesnod:
Old Aug 25, 2003 | 05:43 PM
vvv90's Avatar
vvv90
Default Re: crank case pressure (black bart)
Why? You mean I can't vent my crankcase any other way??? :cry
Old Aug 25, 2003 | 09:49 PM
lead foot 85 vet
what it's a secret and no one else can know?
Old Aug 26, 2003 | 10:20 AM
black bart's Avatar
black bart
No but I have explained this before and those who posted just keep looking for a solution after you have already told them how so unless it is someone that I think really is looking for a solution to their problem why bother. Like I said before I"m making more cylinder pressure than most and I have cured the oil blowing problem. If you want to spend hundreds on experimenting I"M sure their is another way but when someone has already figured it out it is the easy way to go but I guess some just like to keep trying to reinventing the wheel.
[Modified by black bart, 10:49 AM 8/26/2003]
Old Aug 26, 2003 | 01:35 PM
Ronnie_W's Avatar
Ronnie_W
Black Bart, I was going to ask for your remedy but I was afraid that you may have already passed it on to me and I didn't remember. Some of us are getting old and have CRS. Anyway, I would like to know your solution. I have heard several but not sure the best route to take. I hate to have to try them all to find out.
Old Aug 26, 2003 | 05:10 PM
black bart's Avatar
black bart
Ronnie with forced induction you will have blowby can't keep from it the more boost and the more miles on the rings the more blowby. Best and cheapest way that I found is to buy a crankcase evac kit from Summit I got two of the oil separators you will get one way valve like is on the exhaust manifold where the air pump connects and two pieces of half inch pipe to weld into the collectors. For looks I used stainless braided hose. I have a K&N filter on one valve cover and a oil seperator on each cover with hose to each collector. Whenever you are on it hard enought to create blowby the vacuum from the exhaust will draw the fumes into the exhaust if any oil happens to get throught the oil seperator it will just burn in the exhaust pipe. Before I installed this setup I was blowing oil out all over the engine tried several types of beathers but all of them just got soaked and dripped oil everwhere. I didn't mean to sound like a smart azz but when you are sure no one is listening why bother. If you want to see how this setup looks click on the link at the bottom I have pictures of it. Also if you want to drop the water temp check out the grill this is one of the best mods I ever did to my car. I drove it over 50 miles at 85 degrees and the coolant temp ran 174 to 179 fans are set to come on at 185 but never runs unless I"m in town.. I have a stock radiator proves that you don't have to have a $ 500.00 radiator the reason they help is because lack of airflow with air flow the stock radiator will keep it cool :cheers:
Old Aug 26, 2003 | 05:29 PM
vvv90's Avatar
vvv90
damn....now I know why you said wait until I get the new motor in. :leaving:
:thumbs: Don't worry, I'm saving this post so I don't have to bug you again when the time comes :yesnod:
Old Aug 26, 2003 | 05:35 PM
lead foot 85 vet
YOUR THE MAN BART :cheers:
Old Aug 26, 2003 | 06:30 PM
black bart's Avatar
black bart
If you already have headers installed just do what I did. I used a right angle drill to make the holes then weld them in place. Kinda hard to weld on the top side but it can be done. My collectors are full of holes two O2 sensors and two crankcase evac pipes.
Old Aug 26, 2003 | 08:35 PM
black bart's Avatar
black bart
I just checked the Summit web site they now have two crankcase evac systems a Mr.Gasket at $ 31.95 this is just a breather with a hose to the one way valve it would allow oil to pass throough it.
The Moroso is the one that I have it has the oil seperator built into it and sells for $59.95 :leaving:
To crank case pressure
Old Aug 27, 2003 | 10:53 AM
vvv90's Avatar
vvv90
You need two more for the dual pyrometers :lol:
:cheers:
I have stock exhaust, but considering I have to weld for my EGT and O2 sensor anyway, I'm going to get the kit. Thanks Bart!
Old Aug 27, 2003 | 11:39 AM
Ronnie_W's Avatar
Ronnie_W
Thanks Bart, I have the evac kit but am only running one oil separater from the valve cover to the exhaust at this time and one oil separater from the other valve cover to the supercharger intake. I guess I will drill one of the valve covers for a breather and take the line going to the intake and tie it into the exhaust instead.
Old Aug 27, 2003 | 12:22 PM
krivera's Avatar
krivera
BLACK BART...how do you ahve your system set up on the crank case?? :leaving: :leaving:
JOKING! yeah i do remember reading that in the past like 2 years ago... :lolg: :lolg: Ok maybe not that long ago but i think i asked the same question and you said the same thing...but i ran out of doe so i can afford nothing so project slow 4c is at a stand still! Sorry to break you blls but someone has to do it :cuss
