What is a good rack to go with? I can use a Z51 rack in my car with no problems? I have found Autozone to be about the cheapest but that is the part that scares me..
I bought a re-man GM. It made absolutely no difference in feel(should have left the stock one in, o well :D ) it wasn't a Z51 unit. Good luck, I'd go with a GM one.
Mine had a leaking pinion seal so i replaced it with a rebuilt Z51 rack.
Works fine and no more mess on my driveway. It was an easy install and since i didn't mess with anything else i was able to set toe adjustment myself.
While you're in there, install some new tie rod ends too. You'll definitely need to re-align it either way as removing the rack requires the tie rod ends to come off. That'll throw out the toe.
Good luck...and if you need photos, I have some of when I did mine.
See? too many things on this car we're replaced..I can't remember them all. A new pump and hoses went in on mine at the same time as the rack/tie rods.
Jay: sure would appreciate the pics and any tips or tricks you might have, have a rebuilt gm rack waiting to be installed... also tie rod ends, new ps pump and complete cable set...
