86 Picked up a bad miss
Old Aug 24, 2003 | 09:53 PM
jtfrog's Avatar
jtfrog
Default 86 Picked up a bad miss
Well there is probably a thousand answers to this but here i go. I did a complete tune up two months ago and the car has been running fine. I went out side today and started it up and it is missing terribly. WTF. What could cause a sudden miss? The only thing I have been doing is putting in Red Line Complete fuel system cleaner and i am on my secound bottle and half way through the tank of gas?? :sad:
Old Aug 24, 2003 | 11:24 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: 86 Picked up a bad miss (jtfrog)
Have you checked inside dist cap and color of plugs ??
Old Aug 25, 2003 | 01:14 AM
jtfrog's Avatar
jtfrog
Default Re: 86 Picked up a bad miss (AGENT 86)
not yet, it was getting late and after packing all day to move i was wiped out. I am going to work on it in the am. It just seems odd that all of a sudden this would happen :yawn:
Old Aug 25, 2003 | 10:27 AM
jtfrog's Avatar
jtfrog
any ideas?
Old Aug 25, 2003 | 11:26 AM
SunCr's Avatar
SunCr
Make sure there's no white smoke out of the tailpipes which could indicate a head gasket. Check fuel pressure to make sure an injector hasn't stuck open too. My guess would be that it's the ignition module or a plug is missing a puck - did you use the Bosch plugs? - they seem to have this problem.
Old Aug 25, 2003 | 11:35 AM
jtfrog's Avatar
jtfrog
Default Re: 86 Picked up a bad miss (SunCr)
I will look at those things. I used the Rapid Fires by GM. I am going to work on it now i will let you know.
Old Aug 25, 2003 | 12:13 PM
jtfrog's Avatar
jtfrog
It looks like the plugs are fried. They all have a little oil blow by on them. I see a possible valve job comming in my future. Whell for now i will start with the plugs. Wich ones to buy ??
Old Aug 25, 2003 | 12:26 PM
jtfrog's Avatar
jtfrog
It looks like in the polls that rapid fires #1 for the iron heads wich is what I have now. Also the NGK's rated very high. If I go with NGK's wich ons to buy???
Old Aug 25, 2003 | 06:56 PM
jtfrog's Avatar
jtfrog
New plugs , cap and rotor. Car runs 100% better. Heres the kicker. I disconected the ets to check the timming and I could not find the mark. Well after a bought an hour of looking I found the mark 180% off. What the heck happend here
Old Aug 25, 2003 | 08:33 PM
AGENT 86's Avatar
AGENT 86
Are you sure you hooked up to #1 ?
Old Aug 26, 2003 | 05:28 AM
jtfrog's Avatar
jtfrog
Found the problem. The harmonic balancer slipped. :crazy:
Old Aug 26, 2003 | 10:05 AM
AGENT 86's Avatar
AGENT 86
That can't be a good thing :crazy: :smash:
Old Aug 26, 2003 | 01:16 PM
jennykayes84vette's Avatar
jennykayes84vette
How does a harmonic balancer "slip" Never heard of this.
Old Aug 26, 2003 | 04:19 PM
CarAteMyMoney's Avatar
CarAteMyMoney
are you referring to the outer part of the balancer moving at a different rate than the inner part? or did the rubber just start flopping out
if its the rubber flopping out that might not be the only problem
- my mustang ran just fine when the old balancer was falling apart, it didnt start to buck and shake until you could actually SEE the outer hub like not spinning, it was kinda cool looking back :lol:
[Modified by CarAteMyMoney, 5:21 PM 8/26/2003]
Old Aug 26, 2003 | 06:16 PM
jtfrog's Avatar
jtfrog
Default Re: 86 Picked up a bad miss (CarAteMyMoney)
the outer ring slid back towords the timing chain cover. Jenny , the outer ring is pressed on to inner
Old Aug 26, 2003 | 06:20 PM
CarAteMyMoney
thats interesting, did the motor just shake alot, or did the exhaust also sound like it was missing/uneven?
Old Aug 26, 2003 | 08:50 PM
86Pacecar's Avatar
86Pacecar
I just had the same thing happen to me on my 86. The outer ring had slipped back and was actually starting to rub on the timing cover. From my research this is somewhat common problem. I was able to get my puller into the balancer and pull it off. Once off it just fell apart. I experienced no vibration problems that were noticable, not to say there wasn't any.
Old Aug 26, 2003 | 11:47 PM
CarAteMyMoney
Default Re: 86 Picked up a bad miss (86Pacecar)
interesting...
my mechanic said theres a slight miss in my car, possibly a failing cam (110k on stock flat tappet cam)
i know the rubber is slipping out of my balancer, could this be giving me the same symptoms?
To 86 Picked up a bad miss
