C4 - turning back the odometer
Old Aug 31, 2003 | 08:08 PM
Bilyk's Avatar
Bilyk
Default C4 - turning back the odometer
is it possible to turn back to odometer on a C4? i heard there were some features built into these to prevent that
the reason i am asking is because i looked at a vette today with relatively low mileage and i was just wondering what are the odds of that being legit?
Old Aug 31, 2003 | 08:13 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: C4 - turning back the odometer (Bilyk)
The electrical odo ones can have the PCM replaced.... the older ones have to be wound forward, or can be replaced as well.
Old Aug 31, 2003 | 08:14 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
you can allways run carfax or find out where it was serviced and pull a service record if it was ever serviced at dealer they keep track of mileage.Usally if milage was rolled back the numbers dont line up right.how many miles does it have on it.
Old Aug 31, 2003 | 08:23 PM
Bilyk's Avatar
Bilyk
Default Re: C4 - turning back the odometer (crash1mac)
110K km
Old Aug 31, 2003 | 08:40 PM
Bilyk's Avatar
Bilyk
PS: is carfax actually any good?
the reason i am questioning the mileage is because the car has had quite a few owners in the past... but most of them were dealerships
Old Aug 31, 2003 | 09:20 PM
smacko's Avatar
smacko
Whats 'CARFAX'?
Sounds like something we don't have access to here in OZ :confused:
Old Aug 31, 2003 | 09:23 PM
smacko's Avatar
smacko
Be aware too; that the opposite can apply; Too LITTLE miles reading on odo;
If there's a fault in speedo side of dash, (as in my case DAMNIT!!)
the odo will not keep clocking up the miles! So you COULD find yourself buying a car that has a LOT more miles on it than it reads - This MAY be the case in the car you're looking at perhaps??
:smash:
Old Aug 31, 2003 | 09:29 PM
tjwong's Avatar
tjwong
Default Re: C4 - turning back the odometer (smacko)
Yes even an electronic ODO can be turned back. Just remember man made man can fix it. But hopefully you got a good car and everying is OK. Even carfax won't tell you much. Thats because the car had to be repaired at the dealer or some other agency that would have been in the carfax system. If the guy did all or most of his own work as I do there are no records. I have a 95 with less than 10k miles on it, would you beleive it? In reality it does for real.
Old Aug 31, 2003 | 11:17 PM
85vet's Avatar
85vet
Cruise-In V Veteran
110K km
I have an 85 with 58000 miles and it is legitamate. I knew the previous owner.
Old Aug 31, 2003 | 11:27 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
I adopted Mine with 70k on her and she now has 94k all records matched i drive her alot more than the previous owners thier were 2 :auto:
Old Sep 1, 2003 | 03:45 AM
smacko's Avatar
smacko
Default Re: C4 - turning back the odometer (tjwong)
:steering: You should DRIVE it more! :steering:
Old Sep 1, 2003 | 04:22 AM
Darkness's Avatar
Darkness
In the case of the digital ODO it would be a little more difficult cause they would have to reprogram new miles on it and all that electronic crap would be too difficult for these kind of guys. On the other hand, the mechanical ODO is as easy as opening the dash. Less than an hour. I did it once to a car that we transform into racecar and wanted to know real race miles.
:cheers:
Old Sep 1, 2003 | 09:00 AM
Tom Piper's Avatar
Tom Piper
I'm not sure what year started to use the CCM, but my '92 has a CCM that maintains the odometer reading.
The CCM can be swapped out with a CCM from a vehicle with lower mileage. But, the CCM also has the VIN # of the vehicle programmed into it, and you can read the VIN # of the CCM with a Vetronix scan-tool to see if someone changed it.
The only way I know of altering the odometer reading in the CCM so it is undetectable is to get a new or refurbished CCM from GM/Delco and program it before the vehicle has accumulated 100 miles on it -- after a new CCM accumulates 100 mile, you are locked out from programming it. This way you can set the odometer reading and the VIN # to anything you want. But, there is one catch here: Vetronix will not supply anyone but a GM dealer with the software for the Vetronix scan-tool that will do this. So, a shady dealer could easily alter the mileage.
Tom Piper
Old Sep 1, 2003 | 09:01 AM
Bilyk's Avatar
Bilyk
Default Re: C4 - turning back the odometer (Darkness)
it's an 85, so the odometer is mechanical
Old Sep 1, 2003 | 09:10 AM
89CONV's Avatar
89CONV
The previous replies answer your question, but car fax helps, and someone is doing free checks on the C5 FOR SALE section. Best thing to do is check over the car and ensure it runs well and is in good shape. If your happy, then thats all that matters.
:cheers:
Old Sep 1, 2003 | 09:50 AM
Derf's Avatar
Derf
My 86 has 25,500 original miles on it, and yes I should drive it more.
:iagree:
Old Sep 1, 2003 | 10:06 AM
CountryBoy's Avatar
CountryBoy
Default Re: C4 - turning back the odometer (Derf)
The mechanical ones will have a gray line that appears between the digits if tampered with. This is the line that separates the digits. They are normally black until monkeyed with then they rotate to gray. I read this years ago so NO I don't have personal expericence with it. :seeya
Old Sep 1, 2003 | 10:30 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: C4 - turning back the odometer (CountryBoy)
:iagree:
Old Sep 1, 2003 | 10:44 AM
Goody's Avatar
Goody
Default Re: C4 - turning back the odometer (Jeffvette)
It's not the PCM/ECM, but as Tom stated, it is the CCM located up in the dash. Swap out the CCM, but the VIN will give it away.
But, I do know that while in LIMP Mode, a car will not accumulate any mileage. Performance is severly lacking, (no ign advance), but they are drivable.
To C4 - turning back the odometer
