Polish the plenum/runners
Old Sep 1, 2003 | 12:33 PM
Bill-35thAnvrsy-88's Avatar
Bill-35thAnvrsy-88
Default Polish the plenum/runners
Hey all,
I've searched on this topic and there is no real explanation of what to do or how to do it or what to use...especially cleaner wise. I am not talking about polishing to get shiney...just to clean them up...considerably...remove the ingrained grease/dirt. I started using my dremel with a polishing wheel (Felt like wheel) and the dirt started to lift but slowly. Any cleaner I should use?
Thought I'd better stop and ask the experts before I created a nightmare!
What ya think...ideas?
Thanks,
Bill
Old Sep 1, 2003 | 12:38 PM
1MoorTym's Avatar
1MoorTym
Default Re: Polish the plenum/runners (Bill-35thAnvrsy-88)
To just clean them try Simple Green and a bristle or brass brush. Simple Green a great degreaser and pretty mild on you when using it.
Old Sep 1, 2003 | 01:36 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I use a Scotch Brite pad with some cleaner (often Eagle Al polish) to clean Al parts.
Old Sep 1, 2003 | 08:09 PM
LaVidaLoca's Avatar
LaVidaLoca
If you are not looking for high polish but just a brighter aluminum; I used a brass brush in my cordless drill. Also used a couple of small brushes in my Dremel for hard to reach areas. Got rid of the dull finish.
On some of my brackets and other odd shaped pieces I used a sand blasting cabinet and used glass bead material to clean up the aluminum.
Be careful using any acid based aluminum cleaner, it will rust any steel parts it comes in contact with.
Here are some pics, see what you think.
http://f1.pg.photos.yahoo.com/ph/bla....src=ph&.view=
:cheers:
Old Sep 2, 2003 | 01:19 AM
mistaben's Avatar
mistaben
Default Re: Polish the plenum/runners (LaVidaLoca)
wow. that baby is high gloss :cool:
but are you talking about doing that to the inside of the runners? that is what i want to do to mine. my 383 is using the stock tpi and just seems to cut out way to soon in the powerband.
Old Sep 2, 2003 | 04:00 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
LaVidaLoca,
Are you concerned about getting a germ or two from that engine?
Or is it the other way around?
Just joking.... :rofl: :rofl: :rofl: :blueangel:
Old Sep 2, 2003 | 07:16 PM
LaVidaLoca's Avatar
LaVidaLoca
Default Re: Polish the plenum/runners (VetNutJim)
LaVidaLoca,
I shot those pics when I was doing the engine swap. I spent 2 weeks inside the engine compartment cleaning, polishing and painting. By the time I got the new engine in the joke was that it was not just clean, but sterile. So as a joke I brought my scrubs home and took some shots of the "transplant" operation. :lol:
To Polish the plenum/runners
