There is dirt and sand all around and partially in the injector bungs. I got most of it away from the injector bung area, but there was still some grit/sand/dirt when the injectors came out. Should I be concerned?
Other than an AFPR, anything else I should do while I have the the fuel rail off?
i changed the injectors on my 91 and i took a small hand held vacuum and suck all the dirt up. as for your injectors yes put a little oil around the o-rings.
Thanks guys. Also just read some archived posts about it too. Im a little concerned that when the injectors were pulled out, some crap may have dropped into the injector holes. How bad would that be?
I also sucked up all the dirt around the manifold by the injector holes. My injectors were so stuck to the manifold one injector left its o ring and plastic piece around the pintle lodged there. But I got it out. :seeya
Welp, I cleaned them up as best as I could with some Q-Tips. Just hope not much fell in when I pulled the injectors out. I suppose I'll know in a thousand miles or so... *fingers crossed*.
