poping/clunk sound while turning
Old Sep 9, 2003 | 07:58 PM
OrthoAggie's Avatar
OrthoAggie
Default poping/clunk sound while turning
I own a 96 LT1 Coupe that has a poping sound coming from i think the front end of the car. It only makes the sound while making a sharp turn to the left. It also usually does it while I am on the brakes a little. Any ideas on what this might be?
Old Sep 9, 2003 | 09:51 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: poping/clunk sound while turning (deiaggie)
Check for play in your wheel bearings,control arm bushings,sway bar brackets and tie rod ends.
And check caliper guide pins and bracket.
Did i miss anything ? :D :smash:
Old Sep 10, 2003 | 08:11 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: poping/clunk sound while turning (AGENT 86)
:iagree: I would pay particular attention to sway bar bushings and end links.
Have you done or had done any front end work recently?
Jack
To poping/clunk sound while turning
