BBC conversion in C4
Old Sep 12, 2003 | 12:29 PM
USAZR1's Avatar
USAZR1
Default BBC conversion in C4
A few years ago,Corvette Fever or Vette magazine featured an article about installing a big block in a C4. Does anyone remember that article? If anyone has it scanned & saved,could you forward it to me? It would be much appreciated as a friend is interested in installing a 502" in his C4.
Clint
Old Sep 12, 2003 | 12:32 PM
montie98's Avatar
montie98
Default Re: BBC conversion in C4 (USAZR1)
I remember reading this. I am going to go through my old mags to see if I still have it
Old Sep 12, 2003 | 12:39 PM
jburnett's Avatar
jburnett
Default Re: BBC conversion in C4 (montie98)
I have that article somewhere... They used an old Can Am aluminum block and installed it in an '86... Corvette Performance or Corvette Specialists or something like that, out in California I believe.
I put a carbed 496 in an '84 about 8 years ago...It's really not that hard; you do have to clearance the front crossmember and the heater box is in the way as well. Since this was going to be a street racer we pulled the heater core anyway so it wasn't a problem. I believe they cut and resealed it to clear the valve cover and exhaust manifold in the article. They also used OEM Vette BBC exhaust manifolds from an early 70's C3; I would build a set of headers though...
-Jeb
Old Sep 12, 2003 | 12:44 PM
USAZR1's Avatar
USAZR1
Default Re: BBC conversion in C4 (jburnett)
Thanks for the info,Jeb. I wonder if anyone makes headers for this conversion,now.
Old Sep 12, 2003 | 02:07 PM
tjwong's Avatar
tjwong
I have heard that they use a ZR1 heater box that gives adequate clearance. Do a search and you will find a few articles here for the conversion. Some guy here did several of them sometime ago.
Old Sep 12, 2003 | 06:37 PM
BAM92's Avatar
BAM92
Default Re: BBC conversion in C4 (tjwong)
:iagree: Zr1 heater will clear.
Old Sep 13, 2003 | 08:58 PM
Lionsden's Avatar
Lionsden
Do an archive search for 'big block C4' in the C4 Tech section. Twenty threads were found. Here is one.
http://forums.corvetteforum.com/zerothread?id=347516
Or search 'Grumpyvette'. He has done a number of the conversions.
[Modified by Dan Plett, 8:01 PM 9/13/2003]
Old Sep 14, 2003 | 01:32 AM
john25's Avatar
john25
The article is in the August '98 issue of Vette Magazine.
To BBC conversion in C4
