Hypertech Stage III
Old Sep 16, 2003 | 10:11 PM
jodyeastman's Avatar
jodyeastman
Default Hypertech Stage III
I just bought the hypertech to convert my speedo as I changed the rear end ratio. For you guys that may have done this, is there anything I should watch out for? Thanks.
Old Sep 19, 2003 | 01:06 AM
tjwong's Avatar
tjwong
Default Re: Hypertech Stage III (jodyeastman)
Are you using it on a 94/96 C4? Just make sure that your battery is up. Otherwise you can corrupt the memory of the PCM, and that would require replacement or repair of the PCM.
