Lowering ?
Old Sep 18, 2003 | 06:54 PM
CMR250R's Avatar
CMR250R
Default Lowering ?
I am going to lower my 95 I bought the kit from mid america. the problem is all in the front I've read many different opinions on wether or not to install the shims in the front. So what I was looking for is pics of the car lowered with shims and without so that I don't have to do mine twice. Thanks :cheers:
Old Sep 18, 2003 | 09:08 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Lowering ? (CMR250R)
Use the shim or shave the shim but don't rest your bare spring against the cross member. Mine is lowered using a piece of nylon cutting board on top of thin rubber left from original mount. :smash:
:cheers:
Old Sep 18, 2003 | 09:34 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Lowering ? (AGENT 86)
I hate to do this but. :iagree:
Crap.
tony
Old Sep 18, 2003 | 11:40 PM
lt1_corvette93's Avatar
lt1_corvette93
I bought the same kit and shaved the plastic wedges. I havn't had any problems.
Old Sep 19, 2003 | 01:37 AM
Goody's Avatar
Goody
Default Re: Lowering ? (lt1_corvette93)
:iagree: Do not set spring directly on frame. There are weld marks up there that can scratch and cause a stress fracture in the spring. The wedge is there to protect the spring from failure. You can shave it some to get that little smidgen lower if you want it. I have the MAD kit installed and it is plenty low for me. PITA here in SoCal with all the damn dips in the roads.
Old Sep 19, 2003 | 06:05 PM
CMR250R's Avatar
CMR250R
Default Re: Lowering ? (Goody)
do you have a pic goody?
Old Sep 19, 2003 | 06:14 PM
89CONV's Avatar
89CONV
Check the search feature CMR250R since I have viewed great pics of lowered cars when a guy asked the same question as you earlier this year.
:cheers:
Old Sep 19, 2003 | 06:30 PM
CMR250R's Avatar
CMR250R
Default Re: Lowering ? (89CONV)
i actually saw the same pics as you earlier this year and I tried a search the other night but came up with no pics. Thanks. Ill try again later. :cheers:
Old Sep 20, 2003 | 09:22 AM
Dark-Knight's Avatar
Dark-Knight
I used the kit and removed one of the two spacers to rake mine as noted in my sig, no problems.
[Modified by Beautiful Beast, 5:52 PM 9/20/2003]
Old Sep 20, 2003 | 10:15 AM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Default Re: Lowering ? (Beautiful Beast)
The lowering heights will vary with the spring rates as well. I have a 60.0 N/mm spring rate on the front of my '96. I used a VBP lowering kit, I also removed one of the 1/4 metal spacers. I ended up with approximately 3/4" - 1" drop in the front...see sig. :cheers:
To Lowering ?
