800mV @ WOT
Old Sep 18, 2003 | 10:04 PM
91superram's Avatar
91superram
Default 800mV @ WOT
I'm playing with my fuel pressure and was wondering what is the optimal voltage for performance of a O2 sensor from idle to WOT.I have also noticed the more fuel pressure I give the more bottom end I lose so Ive been setting back my TPS voltage to gain it back is It OK to do this?
Old Sep 18, 2003 | 11:52 PM
scorp508's Avatar
scorp508
Default Re: 800mV @ WOT (91superram)
It seems that around ~860-880mv is what people seem to shoot for. The more fuel you add the more lugging of the engine it'll do causing that nasty bog down low.
Old Sep 19, 2003 | 04:03 AM
tjwong's Avatar
tjwong
Default Re: 800mV @ WOT (scorp508)
If you are adding more fuel pressure then you are adding fuel across the board and especially down low. What pressure are you running now? The ECM may not be able to correct enough to get the fuel trims in line at the lower RPMS and TPS points.
It is more advisable to add fuel in the PE tables of your fuel map. But that would take custom tuning of your PROM or PCM which ever you may have. Setting the TPS may or may not make it any better depending on what year your car is the ECM auto zeros in the later model years and anything below .85V is looked at as zero throttle position by the PCM.
[Modified by tjwong, 1:06 AM 9/19/2003]
Old Sep 19, 2003 | 04:56 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: 800mV @ WOT (tjwong)
i try and shoot for 800 mv in high gear at the drags if you want to slow it down some you could add more fuel to bring the mvs back up and richen up the mixture :cheers:
Old Sep 19, 2003 | 09:56 AM
Aaron's 87's Avatar
Aaron's 87
The stock O2 is only a above/below 14.7:1 switch. 800mv ONLY tells you rich. Might be 14.0:1, might be 11.0:1. Tuning for a mv range on a narrow O2 is almost useless.
Old Sep 19, 2003 | 10:00 AM
Dan Parker '96's Avatar
Dan Parker '96
Default Re: 800mV @ WOT (Aaron's 87)
:iagree:
Old Sep 19, 2003 | 11:23 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I'm running 48psi with stock 22lb/hr injectors which gives me about 920-940mV going through the traps. On a dyno with a WB O2 sensor the A/F ratio at WOT was about 12.6:1. I don't have a bog problem with my A4 so don't realy care if it's a little rich at WOT on the low end so long as it's close in mid and upper RPMs.
You can use the stock O2 sensor readings as a rough indicator of A/F though indeed the curve is very flat off stoch so accuracy isn't very good. A few weeks ago Scrop posted some data relating his stock O2 sensor readings vs those using a WB O2 sensor and they correlate pretty well with what I've observed.
You can either tune fuel pressure for best trap speed over several runs (here consistency is the issue) or use a dyno with WB O2 sensor for tuning fuel pressure. If you record the readings from your stock O2 sensor you will then have a tuning guide when adding more air flow mods.
To 800mV @ WOT
