YAY! One header is on!!!
Old Sep 22, 2003 | 07:19 PM
GlockLT4's Avatar
GlockLT4
Default YAY! One header is on!!!
:party:
If you ever put headers on your car, just go out and buy an Exhaust Manifold Spreader now.... it freakin' worked!! :cool: :cool:
Now i get to put the other on, but I'm leaving town on wed for a week to go to chicago ... so i think i'll just get the passenger side all fixed up, start her up to make sure there aren't any leaks .. and then wait until i'm back from town to give it a go on the drivers side. :cool:
[Modified by GlockLT4, 6:22 PM 9/22/2003]
Old Sep 22, 2003 | 08:18 PM
bogus's Avatar
bogus
Default Re: YAY! One header is on!!! (GlockLT4)
you go!
Old Sep 22, 2003 | 09:38 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
Default Re: YAY! One header is on!!! (bogus)
:hurray:
Old Sep 22, 2003 | 09:46 PM
GlockLT4's Avatar
GlockLT4
Default Re: YAY! One header is on!!! (_freakmonkeydogboy_)
Yeah, so i have the header on, but now i've run into a problem getting the flange on the bottom of the header. Well, the bolts look like \ / instead of | | :(. So I either have to bend something down there or I have to drill out the bottom bracket holes larger and hope i can get it to fit that way.
Old Sep 23, 2003 | 12:43 AM
BAM92's Avatar
BAM92
Is this the flange that connects to cats?
Old Sep 23, 2003 | 12:59 AM
GlockLT4's Avatar
GlockLT4
Default Re: YAY! One header is on!!! (BAM92)
Yep, the two studs with nuts, and the one bolt with a welded nut on it.. the ones in a triangle form.
Old Sep 23, 2003 | 01:16 AM
BAM92's Avatar
BAM92
The Hooker I was installing (that sounds bad) used bolts and nuts instead which means you would have to drill yours out. I just got through installing LT headers and they were no harder than shorties. Off the subject,but passenger side had to go in from bottom and driver from top. Driver side for you should not be bad unless your warped again. My used set was. Remove asr and pull it up out of way and lay it on ecm. I remove ac compressor and pulled it up and foward without disconnection lines. Had to grind braces for alt and ac brackets. Thats easy. Goodluck with this bottom flange.
Old Sep 23, 2003 | 01:42 AM
STL94LT1's Avatar
STL94LT1
Instead of using bolts in the flange connection. I installed studs in the header, and drilled the holes out to fit the studs.
Old Sep 23, 2003 | 01:45 AM
GlockLT4's Avatar
GlockLT4
Default Re: YAY! One header is on!!! (STL94LT1)
Yeah, i'm going to have to drill out the holes. Only problem is I can't get the damn cat off of the car. It's stuck on the catback... :rolleyes:
Old Sep 23, 2003 | 01:50 AM
STL94LT1's Avatar
STL94LT1
I drilled mine out with the CATS on the car.
Old Sep 23, 2003 | 02:00 AM
GlockLT4's Avatar
GlockLT4
Ok, good.. i was hoping it could be done that way. You just drilled the holes in the triangular bracket out larger, right? I really want to get that connected so I can see if I've got any exhaust leaks on my header .. before I leave town.
Old Sep 23, 2003 | 10:47 AM
STL94LT1's Avatar
STL94LT1
Yes
To YAY! One header is on!!!
