booby trap
Old Sep 22, 2003 | 09:49 PM
dwestsr's Avatar
dwestsr
Default booby trap
I thought I should share this in case others could have the same thing happen.
I was working on the battery on my 86 C4,when I somehow managed to move the wiring harness to the maf burner relay on the firewall. There was a booby trap there that was waiting 16 years for someone to find . The wires to the relay had the insulation trimed too long so that the bare wires hung out beyond the connector. When the harness was moved these wires got together and started to burn. I had several "exciting" moments before I was able to disconnect the neg battery terminal. Have you ever tried holding burning wires in one hand (to prevent renewed contact) while removing the battery terminal with the other? It aint easy, believe me. I almost lost the whole car .
Fortunately , I was able to rewire that connector , and you can bet it is now well insulated. Anyone else had this experience?
:cuss
Old Sep 22, 2003 | 10:01 PM
loflyin's Avatar
loflyin
Default Re: booby trap (dwestsr)
Check all of your relays, esp the fuel pump relay. My understanding is that the plastic coating shrinks and retracts with age, eventually could lead to what you have already described. Takes a little time, but you may eliminate a short that you didn't even know you had. Good luck, sorry about the hand.
Old Sep 23, 2003 | 04:37 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: booby trap (loflyin)
The wiring going to my fuel pump and to my overdrive solenoid were both coming out of the insulation.
I gummed them up with liquid electrical tape. It's as if GM was trying to save wire.. so everything barely reaches.
Now you've got me paranoid. I'll check those MAF relays tomorrow!
Old Sep 23, 2003 | 07:14 AM
ductape's Avatar
ductape
Cruise-In V Veteran
Guess I better go do that right now :leaving:
Old Sep 23, 2003 | 11:19 AM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: booby trap (CentralCoaster)
:iagree: Liquid tape is the thing to use. Creates a water tight seal and prevents the situation that dwestsr describes. Good stuff.
Old Sep 23, 2003 | 11:32 AM
loflyin's Avatar
loflyin
Default Re: booby trap (Steel Blue 91)
The problem that I've seen with the liquid electrical tape is that heat seems to make it brittle / flaky and the slightest abrasion after it has been there for a while can knock a little off. So if you use it, check on it every so often. I have repaired any questionable connections by heat shrink - alot more work, but seems to hold up and seal much better. Instead of typical crimp connectors on the wiring, I use the smallest diameter copper tubing that the wire will fit into, cut off about 3/4", crimp this in place and then top off with heat shrink. Just be careful of what you aim that heat at! Not saying that my way is better, but this holds and is a viable alternative. Good luck.
Old Sep 23, 2003 | 11:53 AM
SunCr's Avatar
SunCr
My experience with crimps is that they loosen and drop voltage creating intermittents. One of my more uninspiring moments was to crimp a new connector into a MAP with shrink wrap over it. Two years later, the car developed an intermittent stall. After two months of replacing good parts and 2 Dealers later (the first gave up), a scanner with some Mitchell software finally picked up that the ground was opening. It was so momentary there was no code and my Auto Xray couldn't capture it. Since then, I solder everything with either shrink wrap or tape over it. Speaking of tape, where do you guys get yours? The stuff at the discounters, hardware stores, etc, seems to last about a week in an engine compartment (ditto for wire loom).
Old Sep 23, 2003 | 12:11 PM
loflyin's Avatar
loflyin
Default Re: booby trap (SunCr)
Ok, SunCr, you're right. Crimps are bad. Further explanation is that I also add copper epoxy to the ends. Conducts electricity with no increase in resistance, cures in less than 5 minutes, has 20 yr warranty and can only be (per literature) removed by the heat of a torch. Oddly enough was designed for the plumbing industry so is waterproof also. I just got fed up with electrical tape getting "tired".
Old Sep 23, 2003 | 02:37 PM
CentralCoaster
3M electrical tape is supposed to be good stuff. I myself had never really paid attention to the brand before.. but I avoid any electrical tape.
I've always soldered and shrunk wrapped every stereo i've installed.
Old Sep 23, 2003 | 03:36 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Autozone has the "rubber" electric tape that only sticks to itself. I use it exclusively. It does not leave a residue on the wires like electrical tape does. You simply stretch it out, wrap it up and it seals itself. Makes a nice air tight seal as well.
Only problem with it is if you have to remove it. It forms itself into a solid ruber unit and you have to cut it off as you will never be able to undo it like tape.
Old Sep 23, 2003 | 04:26 PM
PonyH8R's Avatar
PonyH8R
Default Re: booby trap (Vette92)
Call me a dummy but I am not clear as to where you are referring to. Do you have a picture? Sorry.
Old Sep 23, 2003 | 05:53 PM
dwestsr's Avatar
dwestsr
Default Re: booby trap (PonyH8R)
sorry, I don't have a picture, but these relays are attached to the firewall behind the battery and slightly above and to the left. I used my gm shop manual to identify them, but i don't have a digital camera(yet).
Old Sep 23, 2003 | 06:11 PM
PonyH8R's Avatar
PonyH8R
OOOHHHHHHH!
Sorry. Now I get it. I better check mine. :eek:
Old Sep 24, 2003 | 07:13 AM
Dark-Knight's Avatar
Dark-Knight
:eek: Yeoow! :eek:
Woulda freaked me out!
Old Sep 24, 2003 | 09:40 AM
mash557's Avatar
mash557
I think that tape is called self-vulcanizing and could be used to seal off a ruptured coolant hose. Would be a good item for the glove/tool box.
Old Sep 24, 2003 | 10:33 AM
bogus's Avatar
bogus
Default Re: booby trap (mash557)
:iagree:
I have also heard the term "Cold Fusion". The stuff rocks.
I don't like using tape, but that is the best tape there is! I have used it on a number of applications, and it never rots, never gets icky. Great stuff!
There have been reports of fires in that area... you may have nailed the ultimate cause.
Great find!!!!!!!!!
To booby trap
