"NEED HELP" Engine heating Problem
Old Sep 25, 2003 | 06:40 AM
EtidW's Avatar
EtidW
Default "NEED HELP" Engine heating Problem
I have a 1996 CE LT4 and just had a new water pump installed. The engine cooling system now operates at 18 deg f higher than it did before the new water pump. I really don't see why.
Has anyone had this happen to them? Does anyoneknow what may be going on here?
Thanks for any and all info
Old Sep 25, 2003 | 09:53 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: "NEED HELP" Engine heating Problem (ETID)
Could have an air pocket in your motor... search here, theres alot on this type of issue.
Old Sep 25, 2003 | 10:05 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Is all the air removed from cooling system ??
Old Sep 25, 2003 | 10:39 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
I think I recall a post a long time ago about the posibility of getting a water pump that will fit but runs backwards. You might find it in an archive search.
Old Sep 25, 2003 | 10:45 AM
vader86's Avatar
vader86
Default Re: "NEED HELP" Engine heating Problem (joecaver)
burp the system again
Old Sep 25, 2003 | 01:47 PM
EtidW's Avatar
EtidW
As far as I can tell there is no air in the system. The new pump assembly came with a thermostat. IT may be that the new ne is a 195 and the old is a 180. Although the information with the new one is that it should be a 180. They are going to take out the new thermostat and put the old one back in and see what that does.
Thanks all.
To "NEED HELP" Engine heating Problem
